- Thank you received: 3
OPCUA: Unexpected error. Retrieved namespace list contain no entries
Thank you for the detailed explanation and for taking time to outline the reasons behind this
- "Not our code", as explained above. In order to work around the issue, we would have to basically fork and modify the UA .NET stack & SDK, and maintain a forked version from this point onwards. That is quite a hassle, and carries relatively high, real costs with it.
- Most OPC servers we deal with are not certified, but do not have any serious issues (or only have the issues we have already taken care of). Let's call them Level 2. Let's call certified server level 3 - they are much better. Then, from time we encounter a server with a serious issue, a "substandard" server - let's call these server Level 1, and we try to work around the issue. But, I have never encountered a piece of software (it is hard to call it OPC UA server) like the one you are dealing with. It would be something like Level 0, or Level -1. It look like that somebody just had hooked together pieces of code handling the very basics of OPC UA protocol, without realizing that OPC UA is not just about message exchange. Even with our "forgiving" philosophy, we have not intended to support such really bad software.
- Developing the workaround would be difficult because we are missing a server (or access to server endpoint) to test with.
- The error you are getting now has to do with missing NamespaceTable in the server. Suppose that we develop a workaround for it. The error will be gone, but there is nothing that guarantees that other stuff will work. You may get a different error then, because there may be more checks inside the UA .NET stack & SDK. It is not quite possible to tell upfront whether something else will have to be changed (worked around) too, how much of it will be needed, and whether it will be realistically possible.
Is it possible to find/implement a workaround for non-compliant OPCUA servers that do not expose mandatory OPCUA address space nodes?
what you are dealing with is not a compliant OPC UA server. From the address space picture you sent, it is missing the whole Server object, an many other things. It can hardly be called OPC UA server at all.
The fact that older QuickOPC version could connect, or that UaExpert can connect, does not invalidate this conclusion.
Not a bug on our side.
2. The customer did not disclose that information, its likely the server resides on PLC
3. The customer did not disclose that information
4. Multiple clients are able to establish connection to the server: UA Expert 1.6, UA Expert 2.0.0, client based on OpcLabs QuickOPC v.5.83.477 (same source code).
5. The issue is reproducible with all 3 communication modes: None, Sign, SignAndEnctypt with exactly the same error
6. The issue happens always Additional information:
- the server has limited protocol support: subscription not supported, probably other limitations
Warning. General: Browsing binary DataTypeSystem failed - no dictionaries found.
Error. AddressSpaceModel: Register for ModelChangeEvents failed: createSubscription returned BadServiceUnsupported
- None of the above prevent UA Expert to browse items and read item attributes including value
- QuickOPC v.5.83.477 is also able to establish connection and poll item value with ReadMultiple method
1) I do not see why this issue should be related to forum.opclabs.com/forum/quickopc-net/4645-opcua-acceptanycer...s-not-work-in-v-5-84-192#14688 except for the fact that it might happen with the same server. Please explain why you think so.
2) Do you know which server it is? (vendor, model, version)?
3) Is the server certified for OPC UA compliance?
4) Are the other OPC UA clients connecting to that server? What clients are they? With what results?
5) What is the message communication mode you use? None, Sign, or SignAndEncrypt?
6) Does this error happen always (i.e. you are unable to ever connect to the server with QuickOPC), or only sometimes?
We are experiencing the issue with "OpcLabs.QuickOpc" Version="5.84.374". It works fine with the same source code and configuration in v "5.83.477"
The issue reproduces on the customer's opcua server which we do not have access to. Let me know what additional information/logs you need to investigate the issue
it is related to the ticket OPCUA: AcceptAnyCertificate does not work in v.5.84.192
