OPCUA: AcceptAnyCertificate does not work in v.5.84.192
11 Sep 2026 12:13 #14688 by support
this appears to be a different issue, please use a separate forum thread in such situation next time please.
Version 5.84 is based on a newer UA-.NETStandard SDK (1.5.378.106) than version 5.83, and in many cases there are more internal checks done inside the SDK, which explains some issues.
However, I could not reproduce your issue; it certainly works well for me with the previous projects you have sent. Please describe how to reproduce. It may very well also be a legitimate error.
11 Sep 2026 11:59 #14687 by Andriy
We are still experiencing the issue with "OpcLabs.QuickOpc" Version="5.84.374". Again, it work fine works fine with the same source code and configuration in v "5.83.477"
[13:44:34 ERR] OnServerConditionChanged: endpoint opc.tcp://xxx:4840 changed to Disconnected. Error: OpcLabs.UAEngine=1 UA SDK error (Opc.UA.ServiceResult=0x80010000) in 'static Session.Create'. OPC UA service result - {BadUnexpectedError}. Retrieved namespace list contain no entries. Retrieved namespace list contain no entries. + Connection attempt #1; last connected at 1/1/0001 12:00:00 AM (local); unconnected for 00:00:00.0310000. + The client method called (or event/callback invoked) was 'ServerConditionChanged'. OpcLabs.EasyOpc.UA.Engine.UAEngineException: UA SDK error (Opc.UA.ServiceResult=0x80010000) in 'static Session.Create'. OPC UA service result - {BadUnexpectedError}. Retrieved namespace list contain no entries. Retrieved namespace list contain no entries. + Connection attempt #1; last connected at 1/1/0001 12:00:00 AM (local); unconnected for 00:00:00.0310000. + The client method called (or event/callback invoked) was 'ServerConditionChanged'. ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {BadUnexpectedError}. Retrieved namespace list contain no entries. Retrieved namespace list contain no entries.    at Opc.Ua.Client.Session.UpdateNamespaceTable(DataValueCollection values, DiagnosticInfoCollection diagnosticInfos, ResponseHeader responseHeader)    at Opc.Ua.Client.Session.FetchNamespaceTablesAsync(CancellationToken ct)    --- End of inner exception stack trace --- == Activity Trace == Following (15) events were gathered during the action on activity ID [15], in the order of first occurrence:   SDK trace: 09/11/2026 13:44:33.997 Imported the PFX private key for zzz (with Private Key).   2*[44] Exception: {Opc.Ua.ServiceResultException} [801A0000] 'Certificate is not trusted.'   [44] SDK trace: 09/11/2026 13:44:34.204 Validation errors suppressed: zzz   2*Exception: {Opc.Ua.ServiceResultException} [801A0000] 'Certificate is not trusted.'   SDK trace: 09/11/2026 13:44:34.252 Validation errors suppressed: zzz   [43] Exception: {Opc.Ua.ServiceResultException} Retrieved namespace list contain no entries.   5*Exception: {System.AggregateException} One or more errors occurred.   2*Exception: {Opc.Ua.ServiceResultException} Channel has been closed. Events starting with activity ID in may not necessarily be related to the current action. PollItems: endpoint opc.tcp://xxx:4840, item ns=1;s=PFC200_WAGO_OPC_SL01 failed. Error: OpcLabs.UAEngine=1 UA SDK error (Opc.UA.ServiceResult=0x80010000) in 'static Session.Create'. OPC UA service result - {BadUnexpectedError}. Retrieved namespace list contain no entries. Retrieved namespace list contain no entries. + Connection attempt #1; last connected at 1/1/0001 12:00:00 AM (local); unconnected for 00:00:00.0310000. + The client method called (or event/callback invoked) was 'ServerConditionChanged'. OpcLabs.EasyOpc.UA.Engine.UAEngineException: UA SDK error (Opc.UA.ServiceResult=0x80010000) in 'static Session.Create'. OPC UA service result - {BadUnexpectedError}. Retrieved namespace list contain no entries. Retrieved namespace list contain no entries. + Connection attempt #1; last connected at 1/1/0001 12:00:00 AM (local); unconnected for 00:00:00.0310000. + The client method called (or event/callback invoked) was 'ServerConditionChanged'. ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {BadUnexpectedError}. Retrieved namespace list contain no entries. Retrieved namespace list contain no entries.    at Opc.Ua.Client.Session.UpdateNamespaceTable(DataValueCollection values, DiagnosticInfoCollection diagnosticInfos, ResponseHeader responseHeader)    at Opc.Ua.Client.Session.FetchNamespaceTablesAsync(CancellationToken ct)    --- End of inner exception stack trace ---
11 Sep 2026 09:57 #14685 by support
please rebuild and retest with QuickOPC 5.84.374, the issue should be fixed.
10 Sep 2026 10:53 #14683 by support
Thank you for reporting this. We will have a fix soon.
07 Sep 2026 14:26 #14679 by Andriy
The global certificate acceptance policy does not appear to be honored in v.
EasyUAClientCore.SharedParameters.EngineParameters.CertificateAcceptancePolicy.AcceptAnyCertificate = true
The server certificate is indeed missing the endpoint URI, however, this is tolerated in v. 5.83.477
We get the following error from the QuickOPC library in v. 5.84.192
PollItems: endpoint opc.tcp://xxxx, item yyy failed. Error: OpcLabs.UAEngine=1 UA SDK error (Opc.UA.ServiceResult=0x80170000) in 'static Session.Create'. OPC UA service result - {BadCertificateUriInvalid}. The Application in the EndpointDescription (urn:vmscada:zzz) is not in the Server Certificate (xxx). [80170000] 'The Application in the EndpointDescription (urn:vmscada:yyy) is not in the Server Certificate (zzz).'
+ Connection attempt #1; last connected at 1/1/0001 12:00:00 AM (local); unconnected for 00:00:00.0320000.
+ This error can be reported by the OPC-UA server if the client application URI has changed but an old application instance certificate was kept. Try to remove and recreate the application instance certificate.
 at OpcLabs.BaseLib.Reflection.Extensions.MethodBaseExtension.FoldedInvoke(MethodBase methodBase, Object obj, Object[] parameters) at OpcLabs.EasyOpc.UA.Sdk.Shims.SessionShim.ValidateServerCertificateApplicationUri(X509Certificate2 serverCertificate, ConfiguredEndpoint endpoint) at OpcLabs.EasyOpc.UA.Sdk.Shims.SessionShim.Open2(String sessionName, UInt32 sessionTimeout, IUserIdentity identity, IList`1 preferredLocales, Boolean checkDomain, Boolean closeChannel) at OpcLabs.EasyOpc.UA.Sdk.Shims.SessionShim.Create(ApplicationConfiguration configuration, ConfiguredEndpoint endpoint, Boolean updateBeforeConnect, Boolean checkDomain, String sessionName, UInt32 millisecondsSessionTimeout, Func`2 identityFunction, IList`1 preferredLocales, Action`2 domainCheckError, Action`1 setupSession, Action`2 setupTransportChannel, CertificateIdentifier applicationCertificate, ICertificatePasswordProvider certificatePasswordProvider) at OpcLabs.EasyOpc.UA.Toolkit.Sdk.ToolkitSession.Create(ApplicationConfiguration configuration, ConfiguredEndpoint endpoint, Boolean updateBeforeConnect, Boolean checkDomain, String sessionName, UInt32 millisecondsSessionTimeout, Func`2 identityFunction, IList`1 preferredLocales, Action`2 domainCheckError, Action`1 setupSession, Action`2 setupTransportChannel, CertificateIdentifier applicationCertificate, ICertificatePasswordProvider certificatePasswordProvider, UAClientSessionBase clientSession)
Following (17) events were gathered during the action on activity ID [15], in the order of first occurrence:
  SDK trace: 09/07/2026 15:53:25.116 Imported the PFX private key for [zzz] (with Private Key).
  [44] SDK trace: 09/07/2026 15:53:25.358 Validation errors suppressed: [xxx],
We did multiple attempts to suppress the validation, including:
  • setting per-endpoint certificate acceptance policy:
      _endpointDescriptor = new UAEndpointDescriptor(settings.EndpointUrl); var policy = new UACertificateAcceptancePolicy() {     AcceptAnyCertificate = settings.AcceptAnyCertificate,     AllowUserAcceptCertificate = false, }; policy.TrustEndpointUrlString(_endpointDescriptor.UrlString); policy.TrustEndpointUrlString("urn:vmscada:xxx"); _endpointDescriptor.CertificateAcceptancePolicy = policy;
  • using test policy:
None of the above suppress the validation.
policy = UACertificateAcceptancePolicy.TestingInsecure;
None of the above suppress the validation.Questions:
  • how we can suppress the validation error?
  • why AcceptAnyCertificate property does not have the expected effect?
  • if we’re using isolated client, does it make sense to configure global EasyUAClientCore.SharedParameters.EngineParameters.CertificateAcceptancePolicy, or should we set policy per endpoint?
