Client supplied certificate instead of username and password
23 Dec 2025 09:36 #14516 by support
The whole procedure from start to end will be server-dependent. QuickOPC does not really care - it just takes the certificate and uses it for authentication according to UA specs.
However, I am also interested how this works with KepServerEx, so I plan to try it out and document if possible. Please be patient, it may be some days before I get to it, also due to the holiday season.
22 Dec 2025 15:59 #14514 by Cwardltu
Thanks I believe this is exactly what I am looking for.
I am using KepServer right now for testing.
Youre correct to I am looking to authenticate the user with the certificate.
I am still not able to connect, I think I am using the wrong certificate. this question may be beyond the scope of OPCLabs but if you know the answer that would be much appreciated. How does one create a certificate that WithX509CertificateIdentity would accept?
20 Dec 2025 09:34 #14509 by support
In the remainder of my reply, I assume that you really want to authenticate the *user* using the certificate, and not the OPC UA *application*. OPC UA applications are always authenticated using the certificates, it is unrelated to user authentication, and done differently in QuickOPC. User authentication with certificates is possible, but relatively rare, so that's why I am a little bit concerned about a possible mixup. (Which UA server or PLC are you using?)
The easiest way to authenticate the user with the certificate is to take an existing UAEndpointDescriptor, and create a new one from it using the WithX509CertificateIdentity extension method:
opclabs.doc-that.com/files/onlinedocs/OPCLabs-ConnectivitySt...ndpointDescriptor,String).html
Also see:
opclabs.doc-that.com/files/onlinedocs/OPCLabs-ConnectivitySt...Authentication%20(Client).html
I hope this helps
18 Dec 2025 21:16 #14506 by Cwardltu
I am trying to find out how to use a client certificate as the token info for a server that does not allow anon users.
the goal is a user can configue a cerificate, user/pass, or both to validate its connection to the server. I can not find much documentation on how to do such a thing or in the examples OPCLabs has provided.
I have provided my most recent attempt here:
        switch (state)         {             case AuthenticationType.UsernamePassword:                 Endpoint.UserIdentity.UserNameTokenInfo = new OpcLabs.BaseLib.IdentityModel.User.UserNameTokenInfo(userName, password);                 break;             case AuthenticationType.Certificate:                 EasyUAApplication.Instance.ApplicationParameters.ApplicationManifest.InstanceOwnStorePath = certificatePath;                 break;             case AuthenticationType.Both:                 Endpoint.UserIdentity.UserNameTokenInfo = new OpcLabs.BaseLib.IdentityModel.User.UserNameTokenInfo(userName, password);                 EasyUAApplication.Instance.ApplicationParameters.ApplicationManifest.InstanceOwnStorePath = certificatePath;                 break;         }
