Client supplied certificate instead of username and password
09 Jan 2026 18:29 #14537 by Cwardltu
Yes I have been meaning to get back to you. Thank you so much for the indepth responce this got me 90% of they way there. the one thing missing was the certs were not being correctly generated. I have included the script i ran that generated the cert with all the extensions needed to work with prosys.
set openssl="C:\Program Files\OpenSSL-Win64\bin\openssl.exe" :: 1. Generate Private Key %openssl% genrsa -out user_private_key.pem 2048 :: 2. Generate Certificate with required OPC UA Extensions :: NOTE: Multiple -addext flags are used to ensure the validator sees all required fields. %openssl% req -x509 -new -nodes -key user_private_key.pem -days 365 ^   -out user_certificate.pem ^   -subj "/C=US/O=MyCompany/CN=John Doe" ^   -addext "keyUsage = critical, digitalSignature, nonRepudiation, keyEncipherment, dataEncipherment" ^   -addext "extendedKeyUsage = clientAuth" ^   -addext "basicConstraints = critical, CA:FALSE" :: 3. Convert to DER (Standard format for OPC UA trust stores) %openssl% x509 -in user_certificate.pem -outform der -out user_certificate.der :: 4. Convert to PFX (For importing into your Client Application) %openssl% pkcs12 -export -keypbe NONE -certpbe NONE -nomaciter -passout pass: ^   -out user_certificate.pfx -inkey user_private_key.pem -in user_certificate.pem -name "John Doe"
Connor
09 Jan 2026 16:26 #14536 by support
I just wonder if you had an opportunity to try out what I described in my latest post. Have you made it work, or do you need anything else?
02 Jan 2026 13:21 #14533 by support
I have documented the code, and steps needed to make it work with Prosys OPC UA Simulation Server, here:  kb.opclabs.com/Authenticating_with_OPC_UA_user_certificate_i...rosys_OPC_UA_Simulation_Server
I hope it helps.
29 Dec 2025 21:04 #14527 by support
I do not quite understand what you mean. There is just one way to use certificates for user authentication in OPC UA, and that is what the WithX509CertificateIdentity method does.
I will try to set it up here with the Prosys simulation server, and document the steps.
29 Dec 2025 20:09 #14526 by Cwardltu
Additionally, I was reading the documentation it seems like the property WithX509CertificateIdentity is not using the cert as authentication. it is taking the user identity from a value in the file from my understanding. This wont work for what I am looking for. is there a way to use the cert as the form of authentication?
29 Dec 2025 13:44 #14525 by Cwardltu
prosysopc.com/products/opc-ua-simulation-server/
This is the one I am using. it has cert auth. Currently I can not get it to work. I'm probably setting it up wrong.
24 Dec 2025 09:35 #14520 by support
Which ProsysOPC server you intend to use? I will investigate the same product.
23 Dec 2025 19:04 #14519 by Cwardltu
I started looking into useing prosys server. it looks as though they support certificate auth.
I am still having issues connecting. I have everything in place. it should work.
I too am going to continue this after the holidays. please let me know if you got it working.
23 Dec 2025 15:11 #14518 by support
I had an initial look. You are right that KepServerEx does not have user authentication via certificates out of the box; but I found this:
support.ptc.com/help/kepware/kepware_server/en/index.html#pa...e/server/uag-certificates.html
So one would have to add the UA Gateway ( www.ptc.com/en/resources/iiot/manufacturing/kepware/infographic/ua-gateway ) possibly?
23 Dec 2025 14:48 #14517 by Cwardltu
Save you some time,
Kepserver does not support certificate user authentication so i am moving to prosys.
