It takes ~6 seconds to load the EasyUAFormsApplication
16 Dec 2024 07:24 #13328 by support
Cannot reproduce it. In my tests, the time to execute this statement is so short that is not noticeable.
Please provide a minimal project that exhibits the problem.
As a workaround, you can do this in a background (example below). That should work unless the user actually needs to execute that command from the system menu before it is added - in your case in first 6 seconds.
Dim SetupSystemMenu = Sub() EasyUAFormsApplication.Instance.AddToSystemMenu(Me) End Sub Dim SetupSystemMenuThread As New System.Threading.Thread(Sub() Invoke(SetupSystemMenu)) SetupSystemMenuThread.Start()
16 Dec 2024 05:50 #13327 by micham
It takes ~6 seconds to add the form using the following API:
Is there a way to improve it?
The customer have to wait 6 more seconds until our main form is loaded...
