It takes ~6 seconds to load the EasyUAFormsApplication
09 Jan 2025 09:48 #13339 by support
EasyUAApplication.Instance
09 Jan 2025 09:45 #13338 by micham
I have added this
Imports OpcLabs.EasyOpc.UA.Application
and now the error is gone, but what should be the value of the application parameter?
09 Jan 2025 09:40 #13337 by micham
Thank you for your answer. I am trying to implement the following, however I get an error on the following line:
Dim application As IEasyUAClientServerApplication
It seems that IEasyUAClientServerApplication is undefined...
IEasyUAClientServerApplicationExtension2.UIAdministerApplication(Application, Form1, New EasyUAClientSelector(EasyUAClient.SharedInstance), True)
I appreciate your answer.
17 Dec 2024 09:44 #13335 by support
Regarding your first post: Administering the UA application from a separate program is in the plans, but not supported yet.
If the issue is with placing the command onto the system menu, and not with running the form itself: There is nothing that forces you to place this command on the system menu. The reason why we "advertise" this method is because it can be used in any Windows desktop application in the same way.
But you can add a command to your application to invoke the OPC UA Administration dialog from anywhere you like - such as your own menus, icons etc. So this is the way I would go in this case. See: opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...UA%20Application%20Dialog.html . Basically, just call EasyUAFormsApplication.Instance.UIAdministerApplication ( opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...2~UIAdministerApplication.html ) when you want the dialog to appear. Suggested arguments are:
- for 'owner': your parent form
- for 'clientSelector': New EasyUAClientSelector(EasyUAClient.SharedInstance)
- for 'allowPullCertificateManagement': True
- for 'allowChangePrivateKeyPassword': False
I hope this helps
17 Dec 2024 09:08 #13334 by micham
Alternatively, can I add your component to another window/form and not to the main window?
16 Dec 2024 20:59 #13333 by micham
Can I handle the "Administer OPC UA Application" from a separate program? If yes, what it the correct way to do it?
16 Dec 2024 16:34 #13332 by support
I cannot reproduce this either.
16 Dec 2024 15:06 #13331 by micham
Hi
I am saying that your solution cases to the form to be "white" for a few seconds until the menu is added to the system menu. The thread didn't help...
16 Dec 2024 15:03 #13330 by support
I do not not want how to interpret the video. I do not know what to expect, therefore I do not see anything wrong. What is that you are trying to say?
16 Dec 2024 14:30 #13329 by micham
Thank you for your answer. See the attached video to see what happens after implementing your suggestion.
2024-12-16...4-55.mp4
