Writing Boolean value results in ArgumentNullException
18 May 2024 09:32 #12804 by support
More detailed logging for this particular area is not available.
Can you try disabling the code optimizations for the process? I have never done that, but it seems that for .NET 6, setting the environment variable COMPlus_JITMinOpts=1 before running the process should do it:
- stackoverflow.com/questions/63959038/how-to-suppress-jit-optimization-in-net-core
- stackoverflow.com/questions/73864832/disable-jit-optimizations-for-specific-net-core-assembly
The idea is that you will end up with the same exception, but better stack trace.
Besides this, I actually know how to work around the issue (but I would prefer finding the cause). The problem is in the area where QuickOPC attempts to obtain the data type of the variable that is being written to. This is only done if the data type is *not* specified in the Write call. Specifying the data type should "resolve" it.
So just use a different overload of WriteValue, and add TypeCode.Boolean as the last parameter -
static public (bool Clamped, bool CompletesAsynchronously) WriteValue( [NotNull] this IEasyUAClient client, [NotNull] UAEndpointDescriptor endpointDescriptor, [NotNull] UANodeDescriptor nodeDescriptor, [CanBeNull] object value, TypeCode typeCode)
The following user(s) said Thank You: Andriy
17 May 2024 15:25 #12801 by Andriy
Is there any way to enable detailed logging for the QuickOPC library? Could this be related to obtaining the node data type from OPC UA server? If so, could you provide the code to fetch the node attributes or any other necessary information before writing the value?
17 May 2024 15:17 #12800 by support
I have examined the call stack.
But it does not help. The code is optimized and the really important stack frames are not listed.
17 May 2024 15:12 #12799 by Andriy
Thank you for your prompt response.
I'm unlikely to reproduce the issue without providing you access to the customer OPC UA server. Could you please examine the attached call stack and determine what might be causing this error?
17 May 2024 14:51 #12798 by support
I do not think this is directly related to the fact that the value is Boolean. In my tests, I can write Boolean values successfully.
Can you put together a test scenario which reliable reproduces the problem?
17 May 2024 10:24 #12797 by Andriy
QuickOPC library 5.63.246, .Net Core 6
Writing a boolean value results in an ArgumentNullException: Value cannot be null. (Parameter 'key')
Can you assist me with this?
System.ArgumentNullException: Value cannot be null. (Parameter 'key') at System.Collections.Generic.Dictionary`2.FindValue(TKey key) at OpcLabs.EasyOpc.UA.Toolkit.Client.UAClientSession.BrowseNodesPreprocess(UABrowseEntry[] browseEntryArray, Exception[]& exceptionArray, List`1[]& sdkNodesToBrowseArray, List`1[]& warningsArray) at OpcLabs.EasyOpc.UA.Toolkit.Client.UAClientSession.InternalBrowseNodes(UABrowseEntry[] browseEntryArray, Exception[]& exceptionArray, UANodeElementCollection[]& nodeElementCollectionArray, List`1[]& warningsArray) at OpcLabs.EasyOpc.UA.Toolkit.Client.UAClientSession.BrowseNodes(UABrowseEntry[] browseEntryArray, Exception[]& exceptionArray, UANodeElementCollection[]& nodeElementCollectionArray, List`1[]& warningsArray) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientSession.DetermineDataTypeInternal(UANodeId dataTypeId, Type& dataType) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientSession.DetermineDataType(UANodeId dataTypeId, Type& dataType) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientSession.DetermineValueType(UAAttributeDataResult dataTypeResult, UAAttributeDataResult valueRankResult, UANodeId& dataTypeId, Int32& valueRank, Type& elementType) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientSession.ReadTypeInformation(IEnumerable`1 nodeDescriptorArgumentsEnumerable)+MoveNext() at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientSession.ObtainTypeInformationInternal(ValueArguments`1[] nodeDescriptorArgumentsArray, ValueResult`1[] typeInformationResultArray) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientSession.ObtainTypeInformation(IEnumerable`1 nodeDescriptorArgumentsEnumerable) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientSession.ResolveWriteList(List`1 resolveWriteList, ICollection`1 internalWriteList, UAWriteResult[] writeResultArray) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientSession.WriteList(List`1 writeList, UAWriteResult[] writeResultArray) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientEngine.Write(ICollection`1 writeListDictionary, UAWriteResult[] writeResultArray) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientEngine.InnerWriteAttributes(UAWriteArguments[] writeArgumentsArray, EasyUAAdaptableParameters easyUAAdaptableParameters) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientEngine.WriteAttributes(UAWriteArguments[] writeArgumentsArray, EasyUAAdaptableParameters easyUAAdaptableParameters) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.NetSdkEasyUAClient.<>c__DisplayClass56_0.<WriteMultiple>b__0() at OpcLabs.BaseLib.Internal.DisposableObject.DisposeGuard[TResult](Func`1 func, Boolean throwOnDisposed) at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.NetSdkEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.ForwardingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.DelegatingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.ErrorTransformingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.ForwardingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.DelegatingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.DataConvertingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.ForwardingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Optimization.Implementation.RequestMergingEasyUAClient.<WriteMultiple>b__3_0(UAWriteArguments[] array) at OpcLabs.BaseLib.OperationModel.Extensions.IReadOnlyListOfOperationArgumentsExtension.MergingPerform[TArguments,TResult](IReadOnlyList`1 argumentsList, Func`2 arrayOperationFunction) at OpcLabs.EasyOpc.UA.Optimization.Implementation.RequestMergingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.ForwardingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.DelegatingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.LicensingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.MultiplexingEasyUAClient.<>c.<WriteMultiple>b__22_0(IEasyUAClient client, IReadOnlyList`1 list) at OpcLabs.BaseLib.Collections.Generic.Extensions.IReadOnlyListExtension.SwitchCase[TInput,TOutput,TKey](IReadOnlyList`1 readOnlyList, Func`2 keySelector, IEqualityComparer`1 keyComparer, Func`3 outputSelector) at OpcLabs.EasyOpc.UA.Implementation.MultiplexingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.ForwardingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.ForwardingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.Implementation.DelegatingEasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.EasyUAClient.WriteMultiple(UAWriteArguments[] writeArgumentsArray) at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteMultipleValues(IEasyUAClient client, UAWriteValueArguments[] writeValueArgumentsArray) at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient client, UAWriteValueArguments writeValueArguments) at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, Object value, Type valueType) at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.WriteValue(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, Object value)
Time to create page: 0.178 seconds
