- Thank you received: 3
Writing Boolean value results in ArgumentNullException
Sorry for the delayed response. I tested the 'browse' and 'write' operations with the new QuickOpc library. Everything is working fine now.
thank you.
Please rebuild your application with QuickOPC 5.80.293, which is now on our Web site and on www.nuget.org . It has the same fix that has been made to the OpcCmd utility you tested with.
Note that there is no guarantee that this will fully resolve your original problem with writing the Boolean value, but the expectation is that at least the ArgumentNullException should go away, and we will make a step forward.
I cannot fully stress out how helpful it was that you have provided the assistance needed to pinpoint the bug. I really appreciate it. Thank you once again.
I tested the new version of the OpcCmd utility, and the browse operation was successful. The "read" and "write" commands are also working properly.
Thank you for your help
thank you for the trace file (received by email). It was really helpful.
I think I have found a bug in QuickOPC that causes the problem. I am not 100% sure, but the likeliness is very high. And I have prepared a new build of OpcCmd with the bug fix.
Can you please download the new version (same location), and repeat the test? For verification, the OpcCmd version should now be 5.81.0.31 or later.
The idea is that if we can make the browsing and writing work with the OpcCmd test, we will then publish a new build of the QuickOPC, with the final verified fix.
I followed your instructions, and the write operation did not fail, but the browse operation did
I got a 'traceoutput' file. I can send it to your email if you need it
here are the instructions for troubleshooting with OpcCmd:
1. Determine what your endpoint URL is. In my example below, I will use "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer", but you need to replace it with your own.
2. Determine what the node Id we want to test is. In my example below, I will use "nsu=http://test.org/UA/Data/;i=10216", but you need to replace it with your own.
3. Download OpcCmd utility from www.opclabs.com/files/downloads/OpcCmd/OpcCmd-Windows.zip .
4. Unpack it into directory of your choice.
5. From command line, go to the directory where OpcCmd is installed, and enter (for interactive mode)
7. Go through initial setup. Select "Interoperability" when asked for standard initial configuration.
8. Enter command
10. Enter command:
13. Enter command:
15. Enter command:
17. Post the file here on the forums, or, if you want to keep it confidential (contains things like computer names, endpoint URLs, node Ids etc.), email it to support09 (at) opclabs.com.
Note: There may be additional steps needed if the server enforces a secure connection.
while I was working on adding the instrumentation for troubleshooting this issue, i have realized that there might be an easier way. We have an OpcCmd utility which allows you to perform various OPC-related operations from command line, and it is of course built on top of QuickOPC. The nice thing about it in this case is that it already has built-in capabilities for configuring the tracing and capturing the output into a file.
So, the idea is that I will give you an up-to-date build of OpcCmd, with the added instrumentation (tracing) for your issue. And step-by-step instructions on what to do: basically, to invoke the failing Write , for which you just need to server's URL, and the node Id of the "problematic" node. And you will run it, and the tool will generate a file with the diagnostics information. The advantage is that you do not have to re-build your application, and modify it to enable the tracing etc.
Let me know if I can proceed in this way.
