EasyOpcUAPubSubDemo Ver. 5.59.0.4
15 Aug 2023 06:54 #11991 by Gunter
As a final note, the "normal" use of UADP is over UDP.
Okay, but "normal" is often from your point of view :-)
My "normal is more
UADP over Ethernet, (TSN), or UAFX (UA FLC, Field Level Communication).
At least for the next view years.....
And since I am more a tester than a software developer, it would be great if I could have a date or timeframe for your next "product release".
Or maybe any pre-release of this specific tool (EasyOpcUAPubSubDemo) ?
I can over you a good test for this tool :-)
Best regards Gunter
14 Aug 2023 16:45 - 15 Aug 2023 06:18 #11989 by support
this is a good catch - thank you for reporting it.
In order to use the Ethernet transport, the project needs to reference the OpcLabs.Pcap package: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20UA%20PubSub%20packages.html .
And, the EasyOpcUAPubSubDemo does not actually do it.
We will fix it into the next product version.
In the meantime, you should be able to do it yourself, by updating the project and rebuilding it.
UADP over Ethernet is meant for more specialized OPC UA use cases that are largely either under spec development or still fairly new, such as real-time communication (TSN), or UAFX (UA FLC, Field Level Communication).
Last edit: 15 Aug 2023 06:18 by support.
The following user(s) said Thank You: Gunter
14 Aug 2023 12:01 #11984 by Gunter
I want to tryout UADP message over Ethernet transport. For this I use your OPCUA Demo Publisher in Interactive mode.
This seems to be working because i can see the Messages in wireshark on the configured Network Card.
But than in a next step i want to see the messages in your Easy OPC-UA PubSub Demo Application. For this i choose:
UADP messages over Ethernet transport, demo publisher on the local network. And than i tried to subscribe.
But this will result in an error message:
Die Datei oder Assembly "OpcLabs.Pcap" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
+ Getting type with name "OpcLabs.Pcap.CaptureDeviceEthernetMessageChannel,OpcLabs.Pcap".
And also when i try to configure the connection for "EthUadp" it always result in error: "OpcLabs.Pcap" oder eine Abhängigkeit davon wurde nicht gefunden
But wireshark is installed and working.
And when i try to use UADP messages over Ethernet transport, data from capture file on disk, this results directly in an exception. I put the debug info here as an attachments.
Would be nice to get any support to get this test running :-)
Gunter
