EasyOpcUAPubSubDemo Ver. 5.59.0.4
18 Aug 2023 10:20 #12029 by support
Great,
thank you for letting me know.
18 Aug 2023 09:30 #12028 by Gunter
Supi it works, well done B)
  • The following user(s) said Thank You: support
    17 Aug 2023 18:11 #12027 by support
    This is going to be difficult to resolve, because I cannot reproduce it here. I think it is because the problem is timing-related.
    But, I have found a possible cause by reviewing the code, and made a change that fixes it. It may, or may not, actually fix the problem you are seeing.
    Please download the current version, i.e. 5.71.334 or later. The About box should show the proper version info now, too.
    The following user(s) said Thank You: Gunter
    16 Aug 2023 13:36 #12013 by Gunter
    1. Which version of Npcap have you installed?
    1.71
    2. Is this on the same computer where you successfully used OpcCmd with Ethernet, or a different one?
    it is the same.
    3. Please check Windows app logs. Start Event Viewer. From the tree, select Event Viewer (Local) -> Windows Logs -> Application. Isn't there an event indicating crash of EasyOpcUAPubSubDemo ? If so, please send its details.
    Yes there are 2 errors, i put the events in the attachments
    Gunter
    16 Aug 2023 12:41 #12007 by support
    I realized that the version number displayed (5.59.0.4) in the About box is incorrect - we will fix it eventually too. It should reflect the QuickOPC versioin installed (5.71....).
    The problem can be due to some incompatibility with the Npcap driver. I have some questions:
    16 Aug 2023 10:06 #12006 by Gunter
    Great.
    Also, the missing reference to OpcLabs.Pcap in the EasyOpcUAPubSubDemo is now resolved in QuickOPC 5.71 build 322.1 or later. It is now in our Web site on the Downloads page.
    I now downloaded and installed your new version of QuickOPC : 2023.1
    But unfortunately, it looks like that EasyOpcUAPubSubDemo Version 5.59.0.0 is not longer working with "pubsub-eth-uadp".
    Every time i try to use it and test connection, the application will closed without any message..... :-(
    When i use "pubsub-udp-uadp" then it still works... :-)
    15 Aug 2023 17:01 #11999 by support
    Great.
    15 Aug 2023 14:45 #11996 by Gunter
    A short feedback:
    i was able to read our mockup over opc.eth:
    With your OpcCmd_Utility. :-)
    Thank you for your good advice
    Gunter
    15 Aug 2023 07:36 #11993 by Gunter
    we can consider making a quick fix into the current version (2023.1) instead.
    This would be great.
    In the meantime, I will look at your other recommendations and see if that helps me.
    Gunter
    15 Aug 2023 07:17 - 15 Aug 2023 07:46 #11992 by support
    "normal" is often from your point of view
    You are completely right, of course :-)
    The next version is planned for November 2023. Is there a problem for you to fix and rebuild the tool as I explained? If it is a problem, we can consider making a quick fix into the current version (2023.1) instead.
    This program (EasyOpcUAPubSubDemo) was meant more for demonstration of the QuickOPC library capabilities, and not primarily as a testing tool, although it can certainly be used like that too.
    Similarly, there is a PubSub support in the Connectivity Explorer application, which you can use too.
    If I were doing testing, however, I would really use the OpcCmd utility. It allows to use all PubSub features of the QuickOPC library from the command line interface, so it even allows some level of test automation and integration.
    - kb.opclabs.com/Category:OpcCmd_Utility
    - kb.opclabs.com/Tool_Downloads#OpcCmd_Utility
    - kb.opclabs.com/Using_OpcCmd_Utility_as_OPC_UA_PubSub_Sniffer
    - kb.opclabs.com/Using_OpcCmd_Utility_as_OPC_UA_PubSub_Subscriber
    In our observation, users are just starting to work with UA PubSub. We have put a lot of effort into development of the PubSub features, and would love to hear feedback and work with the users to learn how they are using the product, what works and what does not, what might be missing, etc. I am really interested. If you have anything to share, or encounter any issues or want to provide feedback, you would be more than welcome!
    Last edit: 15 Aug 2023 07:46 by support.
    Time to create page: 0.150 seconds
