Exception: Cannot browse because the server is not compliant because it does not
01 Dec 2022 15:27 #11277 by support
I do not think this has changed from a previous version. The difference might be due to the fact that I have instructed you to tweak these settings in the past already.
Yes, it can be changed programmatically:
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ultiple%20Implementations.html .
If the program does not set it, it can be set from an "external" configuration file:
- kb.opclabs.com/Intrinsic_Component_Configuration
- kb.opclabs.com/Intrinsic_component_configuration_examples
30 Nov 2022 14:41 #11273 by micham
So what do you suggest?
Can it be done programmatically?
Not that we didn't have this problem in previous versions.
30 Nov 2022 12:11 #11272 by support
30 Nov 2022 07:37 #11271 by micham
Thank you for your answer.
One question: if I will change to EnableNetApiClient = False, can it affect browsing other OPC DA servers?
29 Nov 2022 10:08 #11252 by support
RS Linx OPC browsing is hopelessly broken.
Try to switch to the Native implementation (EnableNativeClient = True, EnableNetApiClient = False).
29 Nov 2022 09:32 - 29 Nov 2022 09:49 #11251 by micham
We are getting this exception when trying to browse the RSLinx OPC server. When using Matrikon OPC Explorer, there is no problem.
I appreciate your answer.
OPC NET API error - result ID: E_UNKNOWN_ITEM_NAME; Cannot browse because the server is not compliant because it does not support the BROWSE_TO function.
+ The item ID used was "STORAGE_HH".
+ The client method called (or event/callback invoked) was 'BrowseNodes'.
Exceptions
OpcLabs.EasyOpc.Engine.NetApiResultException (0xC0040007): OPC NET API error - result ID: E_UNKNOWN_ITEM_NAME; Cannot browse because the server is not compliant because it does not support the BROWSE_TO function.
OpcLabs.EasyOpc.Implementation.ErrorEnhancement.Processed: True
OpcLabs.EasyOpc.Implementation.DAErrorEnhancement.Processed: True
Diagnostic Info:
ErrorCode: -1073479673
HResult: -1073479673 (0xc0040007)
Message:
Source:
TargetSite:
XML Qualified Name 2: opcfoundation.org/DataAccess/:E_UNKNOWN_ITEM_NAME
IsEmpty: False
Namespace: opcfoundation.org/DataAccess/
Message: Problem browsing OPC Data Access (OPC-DA) leaves.
Source:
TargetSite:
QuickOPC version 2021.3 5.62.1032.1
Last edit: 29 Nov 2022 09:49 by micham. Reason: add version info.
