Exception: Cannot browse because the server is not compliant because it does not
09 Jan 2023 16:46 #11424 by micham
Using version 2022.2 I am able to browse RSLINX.
Mike
21 Dec 2022 08:57 #11368 by support
I was able to install the product and reproduce the behavior, but I was not able to work around the issue using an external configuration. In fact, I cannot get my head around the fact that your DAItemDialog is apparently using the NetApi implementation, because the code you have sent only sets the flags on the EasyDAClient object, but in order for it to affect the DAItemDialog, it would have to set the flags in DAItemDialog.ClientSelector.InstanceParameters. Don't you also have code elsewhere that sets these?
Anyway, I proceeded to attempt to rectify the RSLinx version in NetApi implementation in version 2022.2. It now works for me, although, as I wrote, I cannot fully verify it because my RSLinx browsing tree is fairly poor (just two levels of branches, no items). If you know how to configure RSLinx (without the actual hardware) to provide some richer OPC address space with some real (although simulated/internal) items, I would be grateful if you let me know how to achieve that.
Please rebuild your application with the updated 2022.2 version (currently on our Web and NuGet) - build 507.1 or later, and retest.
19 Dec 2022 05:06 #11353 by micham
After you install the product, open UCME Configuration, click on Options > Settings > General and click on the OPC/DDE tab. Browse for the RSLINX OPC Server, add it to the list and click on Save.
Open the Alarms window (Design Alarms) and try browsing for a tag.
Let me know if you have any questions.
19 Dec 2022 04:23 #11352 by micham
Sure. Please find the download link below. Lert me know if you have any questions.
spaces.hightail.com/receive/7jXWxNP5sH
18 Dec 2022 13:44 #11351 by support
Hello, and thank you for the information.
Can you provide me with an installable/executable version of your software? What I want to do is to is to try to provide an external configuration to it that would make the RSLinx browsing work. But I do not want to go through too many "hops" between you and me. So if possible at all, I will check the right procedure on my side, and then send you the instructions that are verified to work.
16 Dec 2022 16:52 - 19 Dec 2022 09:23 #11349 by micham
Thank you for your answer. Now our code supports both .NET APIs and Native Client APIs. The customer can customized this. See the code below.
No matter what we choose, we are getting the same result/error.
Please let me know how should I configure our application eternally or from inside.
If gNET_API Then ' .NET API Client - Dec-1-2022 V2020.6 b617
easyDAClient.InstanceParameters.EnableNetApiClient = True '
easyDAClient.InstanceParameters.EnableNativeClient = False ' Dec-29-2021 V2020.4 b401
Else '
Native API Client
easyDAClient.InstanceParameters.EnableNetApiClient = False ' Dec-1-2022 V2020.6 b617
easyDAClient.InstanceParameters.EnableNativeClient = True '
End If
Form1.DaItemDialog1.ServerDescriptor.MachineName = server_properties.server_comp_name
Form1.DaItemDialog1.ServerDescriptor.ServerClass = server_properties.RealServerName
If Form1.DaItemDialog1.ShowDialog() = DialogResult.OK Then
TagName = Form1.DaItemDialog1.NodeElement.ItemId
'Dim varType As VarType = easyDAClient.GetDataTypePropertyValue("", "OPCLabs.KitServer.2", "Simulation.Random")
Dim value As Object = Nothing
Dim exception As Exception = Nothing
Try '
Catch the exception May-29-2017
value = easyDAClient.GetDataTypePropertyValue(server_properties.server_comp_name, server_properties.RealServerName, TagName)
Catch ex As OpcException
exception = ex
sTagType = ""
DisplayOPCException(exception, server_properties, TagName) ' Feb-17-2022 b404 - display the exception
End Try
Last edit: 19 Dec 2022 09:23 by support.
16 Dec 2022 16:24 #11348 by support
I was able to reproduce the originally reported error (OPC NET API error - result ID: E_UNKNOWN_ITEM_NAME; Cannot browse because the server is not compliant because it does not support the BROWSE_TO function.)
Please let me now summarize, and make a plan. Please correct if something is not right.
A. The problem we want to resolve is the error originally reported (OPC NET API error - result ID: E_UNKNOWN_ITEM_NAME; Cannot browse because the server is not compliant because it does not support the BROWSE_TO function.), because that is the one that appears with your software/your user. We can leave aside the other error mentioned later (OpcLabs.BaseLib.Runtime.InteropServices.ExtendedCOMException (0x80040112): Class is not licensed for use), because it only appears incidentally, with the demo app (not your app) - and I cannot reproduce it.
B. I have verified that the error (OPC NET API error - result ID: E_UNKNOWN_ITEM_NAME; Cannot browse because the server is not compliant because it does not support the BROWSE_TO function.) only appears when the QuickOPC's NetApi client is in use; with the Native client, RSLinx browsing appeared to work for me well (although I only have 2 levels of "branch" nodes - I do not know at this moment how to achieve getting any actual readable/writable items (leaves) - if you know that, please describe to me how to do it in RSLinx). I am quite confident that you can resolve the problem too by properly switching to Native client. If you have not managed it yet, I am ready to work with you to get rid of the error, by configuring your application eternally, or from inside.
C. As I wrote, RSLinx browsing is "special"; the NetApi client code does not work probably because it was not specifically tweaked to cope with RSLinx. I can have a look at whether it can be made to work (so that you do not have to switch to Native client), but it will take some time, and success is not guaranteed.
14 Dec 2022 17:17 #11344 by micham
Please see the download link below for the same RSLINX OPC Server.
Download link>
wetransfer.com/downloads/351ad9f1375f89895a9c1c9107c1d677202...39344a2c320221214111602/af3612
14 Dec 2022 10:20 #11340 by support
If possible (reproducible) at all, I would highly prefer to install the RSLinx on my computer and investigate there. Do you have a download/demo (I might have some very old version somewhere, but using the version that is on site would be much better)?
If that fails, then connect using your method.
13 Dec 2022 21:39 #11339 by micham
It is not a screen sharing connection.
Can I send you the instructions file?
Do you prefer to install the RSLINX OPC server on your computer?
Time to create page: 0.269 seconds
