Faster Queries (OPC read performance)
28 Jun 2012 06:58 #906 by support
Sent: Tuesday, June 26, 2012 1:45 PM
Subject: Re: Faster Queries
thanks a lot for your help. I may have found our bottleneck, we have a bad storage system for all the OPC data and it seems that it slows down everything.
Yours sincerely,
K.
2012/6/24 Zbynek Zahradnik
It should be said that OPC is optimized for subscriptions, and not so much for one-time operations. On average hardware, when subscriptions are used, our component can usually transfer at least 4,000 items *each second*. Single-shot reading is slower, but it shouldn’t be as slow as you are observing. We are shipping an example with the product that demonstrates this with our simulation server. This is one of the examples under the DocExamples project under C# examples solution. Here is the code, for illustration:
// $Header: $
// Copyright (c) CODE Consulting and Development, s.r.o., Plzen. All rights reserved.
// ReSharper disable CheckNamespace
#region Example
// This example measures the time needed to read 2000 items all at once, and in 20 groups by 100 items.
using System;
using System.Diagnostics;
using System.Threading;
namespace DocExamples
namespace _EasyDAClient
partial class ReadMultipleItems
const int NumberOfGroups = 100;
const int ItemsInGroup = 20;
private const int TotalItems = NumberOfGroups*ItemsInGroup;
// Main method
public static void TimeMeasurements()
// Make the measurements 10 times; note that first time the times might be longer.
for (int i = 1; i <= 10; i++)
// Pause - we do not want the component to use the values it has in memory
Thread.Sleep(2*1000);
// Read all items at once, and measure the time
var stopwatch1 = new Stopwatch();
stopwatch1.Start();
ReadAllAtOnce();
stopwatch1.Stop();
Console.WriteLine("ReadAllAtOnce has taken (milliseconds): {0}", stopwatch1.ElapsedMilliseconds);
Thread.Sleep(2 * 1000);
// Read items in groups, and measure the time
var stopwatch2 = new Stopwatch();
stopwatch2.Start();
ReadInGroups();
stopwatch2.Stop();
Console.WriteLine("ReadInGroups has taken (milliseconds): {0}", stopwatch2.ElapsedMilliseconds);
// Example output (measured with Version 5.20, Release configuration):
ReadAllAtOnce has taken (milliseconds): 3432
ReadInGroups has taken (milliseconds): 1563
ReadAllAtOnce has taken (milliseconds): 539
ReadInGroups has taken (milliseconds): 1625
ReadAllAtOnce has taken (milliseconds): 579
ReadInGroups has taken (milliseconds): 1594
ReadAllAtOnce has taken (milliseconds): 638
ReadInGroups has taken (milliseconds): 1610
// Note that Version 5.12 and earlier were yielding much larger penalty to repeated reads.
// Example output (measured with Version 5.12, Release configuration):
ReadAllAtOnce has taken (milliseconds): 4241
ReadInGroups has taken (milliseconds): 8094
ReadAllAtOnce has taken (milliseconds): 269
ReadInGroups has taken (milliseconds): 7813
ReadAllAtOnce has taken (milliseconds): 285
ReadAllAtOnce has taken (milliseconds): 283
ReadInGroups has taken (milliseconds): 7844
private static void ReadAllAtOnce()
var easyDAClient = new EasyDAClient();
// Create an array of item descriptors for all items
var itemDescriptors = new DAItemDescriptor[TotalItems];
int index = 0;
for (int iLoop = 0; iLoop < NumberOfGroups; iLoop++)
for (int iItem = 0; iItem < ItemsInGroup; iItem++)
itemDescriptors[index++] = new DAItemDescriptor(
String.Format("Simulation.Incrementing.Copy_{0}.Phase_{1}", iLoop + 1, iItem + 1));
// Perform the OPC read
DAVtqResult[] vtqResults = easyDAClient.ReadMultipleItems("OPCLabs.KitServer.2", itemDescriptors);
// Count successful results
int successCount = 0;
for (int iItem = 0; iItem < TotalItems; iItem++)
if (vtqResults[iItem].Succeeded) successCount++;
if (successCount != TotalItems)
Console.WriteLine("Warning: There were some failures, success count is {0}", successCount);
private static void ReadInGroups()
// Create an array of item descriptors for items in one group
var itemDescriptors = new DAItemDescriptor[ItemsInGroup];
itemDescriptors[iItem] = new DAItemDescriptor(
// Count successful results (totalling to previous value)
#endregion
// ReSharper restore CheckNamespace
Look at comments in the code that give example measurements. First reading takes much longer, because there are client- and server startup/initial tasks to be done, but still we do not need more than 5 seconds for 2000 items (there are also measurement for Version 5.20 which is not yet released and is even faster). Subsequent readings are much faster.
The measurements show that reading the same set of items in smaller chunks is slower.
Performance will usually highly depend on whether the server can provide the values from cache, or has to read them from device (those two are different methods that OPC provides). Reading from device is much slower with many servers. On our client side, you can control the way the reading is done by setting different values into following parameters:
EasyDAClient.ClientMode.DataSource, www.opclabs.com/onlinedocs/QuickOpcClassic/5.12/Reference/Qu...986-f1a9-5e11-4d64ab497f95.htm - default is ByValueAge
EasyDAClient.ClientMode.DesiredValueAge, www.opclabs.com/onlinedocs/QuickOpcClassic/5.12/Reference/Qu...48e-717f-2373-0d87abf215b0.htm - default is 1000 milliseconds.
Try setting the DataSource to Cache to see if it helps.
Zbynek Zahradnik, OPC Labs
Sent: Thursday, June 21, 2012 5:09 PM
Dear Sir,
thank you for your response.
Currently the connection is local, but in the future there will be remote connection, too.
For debugging reasons the local machine is a normal computer, running Siemens WinCC Flexible in Simulation Mode, so its a average powerful computer, but the software will be running on a SPS or something embedded like it later, therefore i need a perfect result on the debug computer.
What should be a average or good number of items per minute/second (local connection, normal modern computer)?
Yours sincerely,
K.
2012/6/21 Zbynek Zahradnik
Dear Sir,
For any large number of items, the proper method is 2), i.e. with ReadMultipleItems.
The final speed is a combination of performance on the server side and on the client side (+ any communication network). There might be some "tunings" to be done.
I will make a test first using some simulation server here, and let you know then.
Which OPC server are you connecting to, and is it local, or remote?
Thank you, and best regards,
Original Message
Sent: Wednesday, June 20, 2012 12:17 PM
Subject: Faster Queries
Dear Sir / Madam,
I am trying to implement your nice QuickOPC.NET dll into one of our C# programs.
With about 3000 to 6000 entries we have a huge amount of values. I want to read those as fast as possible, but it takes several minutes to read them (up to half an hour).
How is the quickest way to read all those values? I can't find a solution in your help files.
At the moment I have 2 ways implemented:
1) Picking them one by one (OPCClient.ReadItem(choosenMachine, server, item)).
2) Making a Array (OPCClient.ReadMultipleItems(server, itemArray)).
Both have the same (slow) speed.
Can you help me, so we have a good usage of your software?
Yours sincerely,
K.
