"Access Denied" with .NET 4.0
14 Jun 2012 07:11 #889 by support
.NET Framework 4 is supported. There may be differences in how the COM security is initialized, which is probably the cause of the problem. You may need to experiment with DCOM settings, and also with following settings in our component:
EasyDAClient.MachineParameters.TurnOf...
EasyDAClient.ClientParameters.TurnOff...
It would be interesting to know whether the problem is only with subscriptions, or whether it also affects ReadItem[Value] and similar methods. There is a substantial difference between the two, because subscriptions also require that the server can access the client (for callbacks).
Also, if you are running from within a debugger (such as Visual Studio), try running without it. There are security differences as well.
13 Jun 2012 12:34 #888 by Roshan123
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-qformat:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:"Times New Roman";
mso-fareast-theme-font:minor-fareast;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;}
<span style="font-size:11.0pt;font-family:"Calibri","sans-serif";
mso-fareast-font-family:Calibri;mso-fareast-theme-font:minor-latin;color:#1F497D;
mso-ansi-language:EN-US;mso-fareast-language:EN-US;mso-bidi-language:AR-SA">We try to create a simple console application using Quick OPC .NET product (Version 5.12). The targeted platform is .NET framework 4, there we got “Access denied” error in ItemChanged event. When we try the same application on .NET framework 3.5 it works without any issue. Is “Quick OPC .NET” product support .NET framework 4 ?
<span style="font-size: 11pt; font-family: "Calibri","sans-serif"; color: rgb(31, 73, 125);">class Program
Console.WriteLine("Subscribing for 30 seconds...");
EasyDAClient.DefaultInstance.ItemChanged += new EventHandler(_client_ItemChanged);
EasyDAClient.DefaultInstance.SubscribeItem("ptp-test", "DotNova.DASample.80", "SimulatedData.Sine", 100);
Thread.Sleep(30 * 1000);
Console.WriteLine("Unsubscribing...");
EasyDAClient.DefaultInstance.UnsubscribeAllItems();
Console.WriteLine("Finished.");
static void _client_ItemChanged(object sender, EasyDAItemChangedEventArgs e)
try
Console.WriteLine(e.Vtq.Value.ToString());
catch (Exception ex)
Console.WriteLine(e.ErrorMessage);
