Different Timestamp in read and subscribe item
18 Mar 2012 10:06 #804 by support
this problem is fixed in build 5.12.1305.1, which is now available for download from usual location.
The timestamps are supposed to be UTC everywhere, and this is how it behaves after the fix.
13 Mar 2012 13:36 #795 by support
Hello, thank you for your observation.
Unfortunately, it appears that you are right; I was able to reproduce the same thing, which means that there is a bug somewhere in the component. We will investigate it and fix. Please allow some time (most likely, 1-3 days) before the fix can be made available. I will make a post in this forum/thread afterwards.
13 Mar 2012 08:24 #794 by pchirimbu
When I use ReadItem method the Timestamp is corect. But when I use SubscribeItem the Timestamp is 2 hours old. Is Timestamp related to time zone? The Timestamp return different in ReadItem and SubscribeItem? The time zone on my computer is UTC +2.
The same problem appear with the example included in kit.
