How to use WriteMultipleItems method
28 Sep 2010 09:22 #85 by support
Have you inspected the contents of opResults() ? The WriteMultipleItemValues method does not throw exceptions except for coding errors such as invalid arguments - all errors are inside this array, as there may be a mix of good and bad ones, and throwing a single error for the whole operation would not give proper indication of the outcome.
26 Sep 2010 15:28 #84 by ianfenton@rmtrobotics.com
Here's the code. As I said previously there are no errors but data didn't show up on PLC either.Dim m_asTagsToWrite(5) As DAItemValueArgumentsm_asTagsToWrite(0) = New DAItemValueArguments("", se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_MESSAGE, MsgID)m_asTagsToWrite(1) = New DAItemValueArguments("", se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_PARAM_ADAM, tmpMsg.Params.ADAMID)m_asTagsToWrite(2) = New DAItemValueArguments("", se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_PARAM_DEST, tmpMsg.Params.DestinationID)m_asTagsToWrite(3) = New DAItemValueArguments("", se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_PARAM_NEST, tmpMsg.Params.NestID)m_asTagsToWrite(4) = New DAItemValueArguments("", se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_PARAM_PART, tmpMsg.Params.PartID)m_asTagsToWrite(5) = New DAItemValueArguments("", se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_MSG_READY, "True")Dim opResults() As OperationResult = m_OPC.WriteMultipleItemValues(m_asTagsToWrite)So now I am sending each tag separately using m_OPC.WriteItemValue which does work but I'd prefer to do the multiple writes.
23 Sep 2010 13:17 #82 by support
The method that complements WriteItemValue but works with multiple items is named WriteMultipleItemValues, not WriteMultipleItems. Maybe that's why it does not work. If you are using the proper one, WriteMultipleItemValues, and it still does not work, can you please post your code here for review.
23 Sep 2010 13:13 #81 by support
Sent: Thu 9/23/2010 2:54 PM
Subject: RE: WriteMultipleItems
Zbynek,
Thank you fo rthe response. [...]
As a follow up to my post, I tried downloading the newest install for
QuickOPC.NET and the WriteMultipleItems did not generate an error but
it also did not work. Instead I made 6 individual WriteItemValues
calls instead which did work. So for now I am leaving it this way but
I would prefer to use the WriteMultipleItems call.
I.
23 Sep 2010 08:24 #77 by support
I think you may actually want to use WriteMultipleItemValues method. Writing VTQ (Value/Timestamp/Quality) is a feature introduced in OPC-DA 3.0, and not many servers support it (this is fine - it only has its merits for certain cases anyway). So, the error you are getting may be a correct reaction from the OPC server, to a request that it cannot fulfill. I base this conclusion also on the fact that you do not seem to pass anything really "useful" as Timestamp or Quality.
An example for WriteMultipleItemValues can be found in this thread: www.opclabs.com/Support/Online ....
Note that there used to be a bug in this method, so make sure you grab the recent download from this site, or at least verify that you have at least 5.00.1321.1.
23 Sep 2010 08:01 #76 by support
Sent: Thu 9/23/2010 2:41 AM
Subject: WriteMultipleItems
[...] . I am trying to use the WriteMultipleItems method but I keep getting an error, something like "OPC server doesn't support timestamp and/or state"...or somthing like that. I can't figure out how to populate the array for the write. Can you tell me what I am doing wrong? Here is the code snippet after trying several variations;
Dim m_asTagsToWrite(5) As DAItemVtqArguments
Dim MsgID As String = fnConvertMessagetoID(tmpMsg.Command)
m_asTagsToWrite(0) = New DAItemVtqArguments(se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_MESSAGE, New DAVtq(MsgID), New Object()) ', Nothing, Nothing) ', Now, New DAQuality())
m_asTagsToWrite(1) = New DAItemVtqArguments(se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_PARAM_ADAM, New DAVtq(tmpMsg.Params.ADAMID), New Object()) ', Now, New DAQuality())
m_asTagsToWrite(2) = New DAItemVtqArguments(se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_PARAM_DEST, New DAVtq(tmpMsg.Params.DestinationID), New Object()) ', Now, New DAQuality())
m_asTagsToWrite(3) = New DAItemVtqArguments(se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_PARAM_NEST, New DAVtq(tmpMsg.Params.NestID), New Object()) ', Now, New DAQuality())
m_asTagsToWrite(4) = New DAItemVtqArguments(se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_PARAM_PART, New DAVtq(tmpMsg.Params.PartID), New Object()) ', Now, New DAQuality())
m_asTagsToWrite(5) = New DAItemVtqArguments(se.ServerClass, "Channel1.ADAM_GE.API." & TAG_IN_MSG_READY, New DAVtq("True"), New Object()) ', Now, New DAQuality())
Dim opResults() As OperationResult = m_OPC.WriteMultipleItems(m_asTagsToWrite)
I hope you can understand this code enough to figure this out because I've tried everything I can and can't figure it out.
Thank you. Submitted By: I.
