SIEMENS SIMOTION
22 Nov 2011 19:30 #651 by support
Replied by support on topic Re: SIEMENS SIMOTION
22 Nov 2011 19:29 #650 by support
Sent: Tuesday, November 22, 2011 8:26 AM
Subject: R: SIEMENS SIMOTION
Thank you very much.
If is possible we need to test your OPC, there is al link to download a trial version?
Best Regards
<span style="font-family: "Calibri","sans-serif"; font-size: 11pt; mso-ascii-theme-font: minor-latin; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">L.
21 Nov 2011 17:33 #635 by support
We regularly test our software with Siemens OPC Servers - last time on OPC Interoperability Workshop in Nuremberg in September 2011 - and it works well.
I am not sure which of the Siemens servers is in question, but as long as it provides OPC Data Access or OPC Alarms and Events (the specifications that our client software supports; OPC Unified Architecture will be released by January 2012), there is no reason why it should not work.
You can test it out by downloading the trial software from our Web page.
I would be happy to help you set it up and answer any additional questions.
21 Nov 2011 16:23 #631 by support
SIEMENS SIMOTION was created by support
Sent: Monday, November 21, 2011 10:53 AM
Subject: SIEMENS SIMOTION
Good morning,
we need to connect one Siemens Simotion with a scada system.
We need a OPC client for connect our scada with a Siemens OPC server installed on SIMOTION.
Is your client able to conumicate with this OPC Server?
Submitted By: L.
