E_NETWORK_ERROR when reading OPC DA item DataType property
13 Oct 2026 06:53 #14729 by support
We have tested with this version.
We could not reproduce the problem.
The following user(s) said Thank You: Andriy
08 Oct 2026 09:23 #14724 by Andriy
You can download OPCDA  Server v. 3.5.10.20 from CodeSys web site  CODESYS Development System V3 | CODESYS Store International
    06 Oct 2026 13:02 - 06 Oct 2026 13:06 #14717 by support
    Unfortunately such version is not available on  store.codesys.com/en/codesys-opc-da-server-sl.html .
    What should we use?
    Currently available are:VersionRelease NotesRelease Date
    3.5.22.40Includes the following Security fixes: 2026-11 30.09.2026
    3.5.22.30-23.07.2026
    3.5.22.20-20.05.2026
    3.5.22.10-02.04.2026
    3.5.22.0-24.03.2026
    3.5.21.60-22.04.2026
    3.5.21.40Includes the following Security fixes: 2025-09 , 2025-10 , 2025-11 01.12.2025
    3.5.21.30-25.09.2025
    3.5.21.20-04.08.2025
    3.5.21.10-26.05.2025
    3.5.21.0-18.03.2025
    3.5.20.70-21.05.2026
    3.5.20.60-22.04.2025
    3.5.20.50-23.01.2025
    3.5.20.40-20.11.2024
    3.5.20.30-23.09.2024
    3.5.20.20-31.07.2024
    3.5.20.10-04.06.2024
    3.5.20.0-19.03.2024
    3.5.19.70-02.05.2024
    3.5.19.60-06.02.2024
    3.5.19.50-04.12.2023
    3.5.19.40-23.10.2023
    3.5.19.30Includes the following Security fixes: 2023-10 05.10.2023
    3.5.19.20-03.08.2023
    3.5.19.10-01.06.2023
    3.5.19.0-08.03.2023
    3.5.18.60-31.10.2023
    3.5.18.50-04.05.2023
    3.5.18.40-13.12.2022
    3.5.18.30-06.10.2022
    3.5.18.20Includes the following Security fixes: 2022-10 03.06.2022
    3.5.18.0Includes the following Security fixes: 2022-04 06.04.2022
    3.5.17.50-28.10.2022
    3.5.17.40-10.06.2022
    3.5.17.30-25.01.2022
    3.5.17.20-02.11.2021
    3.5.17.10-23.07.2021
    3.5.17.0Includes the following Security fixes: 2020-06 , 2021-01 28.04.2021
    3.5.16.60-18.08.2021
    3.5.16.50-26.05.2021
    3.5.16.20Quality update with minor improvements and bug fixes.Includes the following Security fixes: 2020-06 24.09.2020
    3.5.16.10Quality update with minor improvements and bug fixes.22.07.2020
    3.5.16.0Includes the following Security fixes: 2019-08 , 2020-02 05.05.2020
    3.5.15.40Quality update with minor improvements and bug fixes.Includes the following Security fixes: 2020-02 25.03.2020
    3.5.15.30Quality update with minor improvements and bug fixes.23.01.2020
    3.5.15.10Quality update with minor improvements and bug fixes.19.09.20193
    .5.15.0-29.07.2019
    3.5.14.40Quality update with minor improvements and bug fixes.23.08.2019
    3.5.14.30Quality update with minor improvements and bug fixes.24.06.2019
    3.5.14.0Beside other fixes this is a security update which solves the issues noted in the following advisories:
    2018-11 , 2018-14 17.12.2018
    3.5.13.30Security update: 18.01.2019
    3.5.13.10-23.08.2018
    3.5.13.0-10.07.2018
    3.5.12.70Security update: 13.11.2018
    3.5.12.0-20.12.2017
    3.5.11.50-16.02.2018
    3.5.21.50-18.02.2026
    Last edit: 06 Oct 2026 13:06 by support.
    06 Oct 2026 12:53 #14716 by Andriy
    CodeSys OPCDA server version is 3.5.10.20RC
    05 Oct 2026 14:40 #14713 by Andriy
    CODESYS 3.5 SP19 Patch 7 is the version of CODESYS installed on the customer's system. I will verify the exact version of the OPC DA Server tomorrow
    05 Oct 2026 14:29 - 05 Oct 2026 14:30 #14712 by support
    Please re-specify the precise CODESYS product and version you are using.
    The closest we have found is this one:
    CODESYS OPC DA Server SL
    Available from  store.codesys.com/en/codesys-opc-da-server-sl.html
    Version: 3.5.19.70
    Is it this one, or something else?
    Last edit: 05 Oct 2026 14:30 by support.
    05 Oct 2026 05:22 #14711 by support
    current status: Tested with CODESYS V3.15, because that's what we could our hands on quickly. Could not reproduce the issue.
    Trying to obtain CODESYS version close to yours. Would be nice if you can get send it to us.
    02 Oct 2026 13:00 #14709 by Andriy
    Hello
    1. The behavior is 100% consistent: always fails
    2. Server is local
    3. Tested with Connectivity Explorer and Softing OPC test client. Both clients display property values without error
    4-5. Tested 4 properties (DataType, AccessRights, Value, Quality) on several items - all failed with the same E_NETWORK_ERROR
    Updated to version QuickOPC: 5.84.374 - the same error
    24 Sep 2026 15:53 #14699 by support
    Some questions:
    1. Is this consistent behavior (happens always), or does it happen just sometimes?
    2. Is the server actually remote, or local?
    3. Please clarify "OpcLabs test clients read properties without error" - which clients?
    4. Have you tried other properties (not just DataType), and if so, what were the results?
    5. Does it happen only on specific OPC items, or on any item?
    24 Sep 2026 07:42 #14697 by Andriy
    Environment:
    .NET: 10.0;
    QuickOPC: 5.84.294
    OPC DA Server: CODESYS 3.5 SP19 Patch 7
    GetDataTypePropertyValue fails with E_NETWORK_ERROR while standard read/write operations to the same server succeed.
    Other clients tested: Softing OPC Client and OpcLabs test clients read properties without error from the same server.
    Stack Trace:
    OpcLabs.EasyOpc.OperationModel.OpcException: An OPC operation failure with error ID '{http://opcfoundation.org/DataAccess/}E_NETWORK_ERROR.0xFFFFFFFF' occurred, originating from '' and with depth of 1. The inner exception contains details about the problem.  ---> OpcLabs.EasyOpc.Engine.NetApiResultException (0xFFFFFFFF): OPC NET API error - result ID: E_NETWORK_ERROR; Could not connect to server.; + The client method called (or event/callback invoked) was 'GetMultiplePropertyValues[1]'.    --- End of inner exception stack trace ---    at OpcLabs.EasyOpc.Implementation.EasyUtilities.CheckSuccess(OperationResult operationResult)    at OpcLabs.EasyOpc.DataAccess.IEasyDAClientExtension.GetPropertyValue(IEasyDAClient client, DAPropertyArguments propertyArguments)    at OpcLabs.EasyOpc.DataAccess.IEasyDAClientExtension.GetPropertyValue(IEasyDAClient client, ServerDescriptor serverDescriptor, DANodeDescriptor nodeDescriptor, DAPropertyDescriptor propertyDescriptor)    at OpcLabs.EasyOpc.DataAccess.Extensions.IEasyDAClientExtension2.GetPropertyValue[TValue](IEasyDAClient client, ServerDescriptor serverDescriptor, DANodeDescriptor nodeDescriptor, DAPropertyDescriptor propertyDescriptor)    at OpcLabs.EasyOpc.DataAccess.Extensions.IEasyDAClientExtension2.GetPropertyValueInt16(IEasyDAClient client, ServerDescriptor serverDescriptor, DANodeDescriptor nodeDescriptor, DAPropertyDescriptor propertyDescriptor)    at OpcLabs.EasyOpc.DataAccess.Extensions.IEasyDAClientExtension2.GetDataTypePropertyValue(IEasyDAClient client, ServerDescriptor serverDescriptor, DANodeDescriptor nodeDescriptor)
    Time to create page: 0.184 seconds
