OPCUA: Automatic reconnect functionality is unstable in QuickOPC 5.84
11 Sep 2026 12:18 #14689 by Andriy
Great, it seems the issue is fixed
11 Sep 2026 09:57 #14684 by support
please rebuild and retest with QuickOPC 5.84.374, the issue should be fixed.
The following user(s) said Thank You: Andriy
01 Sep 2026 12:26 #14678 by support
thank you for the projects, I was now able to reproduce the issue.
I have a fix in the works. I am leaving the office now, and will be out for a week. I will not be able to move this into the production today, but there is a positive side to it: I will start a really long-running test before I leave, and plan to check it from time to time.
You should hear from me again towards end of the next week.
31 Aug 2026 12:32 - 01 Sep 2026 06:46 #14675 by Andriy
Here you can find an archive containing a simple .net server/client application that reproduces the error.
The problem can be reproduced consistently the first time after rebuilding the solution. It also occurs from time to time when two OPC UA clients are running
Steps to reproduce
  1. Build and run the OPC UA server in Debug configuration.
  2. Build and run 1 or 2 OPC UA clients in Debug configuration.
  3. Go back to the OPC UA server console and enter: "restart 5 1"
  4. Only the "Disconnecting" event is fired.
  5. The OPC UA client loses the ability to reconnect (no "Disconnected" event).
[Moderator: attachment downloaded and removed, for privacy reasons upon OP's request]
Last edit: 01 Sep 2026 06:46 by support.
27 Aug 2026 11:00 #14674 by support
The expected upon server restart, when monitored item subscriptions are present, is roughly as follows:
1. When the server shuts down, all subscribed monitored items receive an error through DataChangeNotification (.Exception is not null). The precise errors depends on many factors.
2. ServerConditionChanged event is raised, optionally with Disconnecting, but then certainly with Disconnected status.
3. QuickOPC should make reconnection attempts (observable through ServerConditionChanged going to Connecting etc.). Monitored items may receive additional errors to update their status. When a connection attempt succeeds, ServerConditionChanged with Connected should be raised, and all monitored items should eventually receive valid data.
I disagree with that the error message is misleading. it uses the words "the server may have rejected", clearly indicating that what the message is describes is just one of possible causes of the error. It would use the words "the server has rejected" if it was the only option.
I agree that QuickOPC should reconnect. I tried but I could not reproduce the issue. There are many ways the server can go about disconnecting/restarting, so something is different in your tests. I therefore have additional questions:
1. Which OPC Server are you using?
2. How do you restart it?
3. Is the server on your PC or on the network?
4. You reported that you get ServerConditionChanged event with Disconnecting. Do you also get one with Disconnected? (my understanding is that you do not Disconnected, but want to be 100% sure).
25 Aug 2026 12:53 - 25 Aug 2026 12:55 #14673 by Andriy
.NET Core 8, QuickOPC v.5.84.294 and v5.84.192.Scenario:
1. UA client is initialized with property Isolated = true, EasyUAClientCore.SharedParameters.EngineParameters.ReconnectPeriod is explicitly set to 2000
2. Client is connected and active subscription exists for several OPC UA items
3. Quickly restart the OPC UA server4. "OnDataChangeNotification" event (sometimes) is fired for all subscribed items with error like:
"OpcLabs.EasyOpc.UA.Engine.UAEngineException: OPC-UA client session is not available when connecting the client subscription. Session error: "OPC UA service result - {BadSecureChannelClosed}. [80860000]."
and additional misleading message like
"The server may have rejected the connection because it does not trust the client (e.g. certificate problem); check the diagnostics on the server side, if possible."
4. "OnServerConditionChanged" event is fired with EasyUAServerConditionChangedEventArgs.ConnectionState = "Disconnecting" and error like
"Error: OpcLabs.UAEngine=4704 The OPC-UA server has shut down or is in the process of shutting down. The application is releasing all connections to this server. The application will try to reconnect to the server after a configurable period.
+ The client method called (or event/callback invoked) was 'ServerConditionChanged'.
OpcLabs.EasyOpc.UA.Engine.UAEngineException: The OPC-UA server has shut down or is in the process of shutting down. The application is releasing all connections to this server. The application will try to reconnect to the server after a configurable period.
+ The client method called (or event/callback invoked) was 'ServerConditionChanged'."
5. No more reconnect attempts happened. "ServerConditionChanged" event or "OnDataChangeNotification" are never invoked again regardless of server state. No TCP communication with the server. If not reproduced, go to (step 3).
The issue is not reproducible with QuickOPC v.5.83.1181, where ServerConditionChanged is subsequently fired with 'Disconnected', then 'Connecting', then 'Connected'
Last edit: 25 Aug 2026 12:55 by Andriy.
