EasyUAClient SignAndEncrypt Basic256Sha256 Username and Password
thank you for posting this.
I'd like to point out that if the code is meant to be complete, then the part that creates and configures the new UACommunicationProfile object is unnecessary, because all it does is that it creates an in-memory object that is not then used for anything. The code behaviour would be the same without those 3 lines. It probably works due to the QuickOPC auto-negotiation of the endpoint.
If you really wanted to make sure that the specified message security mode and security policy URI is used (and nothing else, ever), you will keep these lines, but also assign the "inst" into "myEndpointDescriptor.EndpointSelectionPolicy.CommunicationProfile" .
- AlexSFromG
Topic Author
- Offline
- Premium Member
- Thank you received: 0
finally I got a code that works for me.
OPC Labs Version 5.84.294.1
Requirements: Open Connection with username and password, Security Mode SignAndExcrypt, SecuityPolicy Basic256Sha256
In Visual Basic 2019:
Dim nodeDescriptor As String = txtNodeDescriptor.Text
Dim inst As New UACommunicationProfile
inst.MessageSecurityModes = Engine.UAMessageSecurityModes.SecuritySignAndEncrypt
inst.SecurityPolicyUriString = Engine.UASecurityPolicyUriStrings.Basic256Sha256
Dim myEndpointDescriptor As UAEndpointDescriptor = New UAEndpointDescriptor(txtEndpointDescriptor.Text)
myEndpointDescriptor.UserIdentityInfo.UserNameTokenInfo.UserName = txtUsername.Text
myEndpointDescriptor.UserIdentityInfo.UserNameTokenInfo.Password = txtPassword.Text
Dim myC As New EasyUAClient()
Dim value As String = myC.ReadValue(myEndpointDescriptor, NodeDescriptor)
MessageBox.Show(nodeDescriptor & " >>" & value.ToString & "<<")
I hope somebody will save time in looking for this solution.
Alex
Right-click on the server node, select the User Identity command, specify the credentials, press OK. It should work then.
I hope this helps.
- AlexSFromG
Topic Author
- Offline
- Premium Member
to become more experienced what to do I used the examples which come with the demo. In the easyopcua example
I can connect ot my opcua server. The user identity provided is detected as anonymous.
But when I try to connect to a node id I get the error
OPC UA service result - {BadIdentityTokenRejected}. Endpoint does not support the user identity type provided. Endpoint does not support the user identity type provided.
How can I troubleshoot this behaviour?
Alex
Your code for username / password looks good.
By default, QuickOPC negotiates the message security model and security policy with the server. So, for example, if the server only allowed SignAndEncrypt and Basic256Sha256, this is what will get used, without further effort.
If you need to make sure specific values are used from the client side, set the parameters inside myEndpointDescriptor.EndpointSelectionPolicy.CommunicationProfile. Specifically:
- www.doc-that.com/files/onlinedocs/OPCLabs-ConnectivityStudio...file~MessageSecurityModes.html
- www.doc-that.com/files/onlinedocs/OPCLabs-ConnectivityStudio...e~SecurityPolicyUriString.html
I hope this helps
- AlexSFromG
Topic Author
- Offline
- Premium Member
i need some help.
My OPC-Admin gave me a username and a passwort. He said the security mode is "SignAndEncrypt" and the Security Police "Basic256Sha256".
How can I use this information to connect to the server?
My code goes like ...
Dim myEndpointDescriptorString = txtEndpointDescriptor.Text
Dim myEndpointDescriptor As New UAEndpointDescriptor(txtEndpointDescriptor.Text)
myEndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName = "xxxxxxxxx"
myEndpointDescriptor.UserIdentity.UserNameTokenInfo.Password = "yyyyyyyyyyy"
But this cannot work as the info for security mode and policy are missing.
Is there an example how to do it? Or do you have a hint for me?
Alex
