Error BC30456 'AllowedMessageSecurityModes' is not a member of 'UAEndpointSelect
13 Jun 2026 09:39 #14651 by support
Yes, there has been a change. Please modify your code to use uaDataDialog1.EndpointDescriptor.EndpointSelectionPolicy.CommunicationProfile.MessageSecurityModes
instead,
(the new object is mentioned, but admittedly not best described, here  kb.opclabs.com/What%27s_new_in_OPC_Studio_2025.1 ).
13 Jun 2026 08:43 #14650 by micham
I am getting the following build error after upgarding to NuGet version 5.82.423.
Severity    Code    Description    Project    File    Line    Source    Suppression State
Error    BC30456    'AllowedMessageSecurityModes' is not a member of 'UAEndpointSelectionPolicy'.
My code is below:
If server_properties.pSecurityMode = "Sign&Encrypt" Then
      uaDataDialog1.EndpointDescriptor.EndpointSelectionPolicy.AllowedMessageSecurityModes = UAMessageSecurityModes.SecuritySignAndEncrypt ' Sign&Encrypt
End If
Time to create page: 0.188 seconds
