EasyUAClient client cannot reconnect
29 May 2026 05:51 - 29 May 2026 05:51 #14645 by support
You are instructed to use the provided newer version and the traces it generates. We will not look at anything else.
Last edit: 29 May 2026 05:51 by support.
29 May 2026 03:31 #14644 by xpycy001
Hi,Support:
There is another issue, I am not quite sure about the differences between the two versions.
 I directly used the current on-site version(QuickOpc 5.83.1043.1) and also enabled the interception log function(system.diagnostics).
It seems that the internal interception logs are also very rich,
and I did not find any special differences from the logs of the (OpcLabs. QuickOpc 5.85.0-rev0003) test version;
Simon.Yu
vskysoft.com
2026.5.29 11:33
26 May 2026 16:20 #14643 by support
Ad 1) We will send you an evaluation license key, valid for 60 days (which can be renewed should the need arise), to the email address you used to register with the Online Forums. This will overcome the 30-minute runtime limit. Warning: Make sure to observe its end day, because at that date it will stop working.
Ad 2) Good.
Ad 3) OK.
Ad 4) Whatever happened with earlier version isn't of much use now, because of missing tracing.
Ad 5) Good.
The following user(s) said Thank You: xpycy001
26 May 2026 10:24 #14642 by xpycy001
Hi,Support:
After on-site release, several issues were identified and summarized as follows:
(1) After startup, it was found that there was a prompt for the demo version on the console, so it could only be a temporary test for a short period of time. Considering that the project needs to run stably, it is uncertain whether there is a problem of stopping the collection (demo version, which stopped collecting after using for 30 minutes before)
(2) According to the prompt you provided, trace logs have been enabled, and you can indeed see detailed logs in the trace directory with a lot of information content (enabled: system. diagnostics)
(3) The on-site testing time is relatively short, and there are currently no logs of large batches of rapid, continuous, and high-frequency disconnections as before
(4) Abnormalities that have been present for the past 1-2 weeks:
In multiple point subscriptions in an OpcServer, there are a few points where the signal is lost and the subscription cannot be made (value changes can be continuously subscribed through third-party tools). There are a few logs of disconnection reported in ServerConditionChange, but another event still receives value changes (easyUAClient. DataChangeNotification). However, other points in the same OpcServer server receive value change notifications normally;
(4.1) No special logs were found in the EasyUAClient. LogEntry event
(4.2) No relevant logs were seen for the HasBadStatus status change log of the monitoring target location
(4.3) The program on the customer's site has been rolled back to the previous version: 5.83. Temporary application layer logic monitoring has been added to determine the (3) problem and force the re creation of EasyUaClient isolated object instances for different IPs, and force re subscription to solve it;
(5) I plan to continue conducting in-depth testing in the early stages of another new project, and if there are significant findings, I will report them promptly
Simon.Yu
vSkysoft.com
2026.5.26 18:25
26 May 2026 01:50 #14641 by xpycy001
Hi ,Support:
I am glad to receive this letter,  I will put myself into testing first, and regardless of the results, I will provide timely feedback
Simon.Yu
vskysoft.com
2026.5.26
25 May 2026 13:59 #14640 by support
Hello.We have implemented additional tracing into a pre-release version, available as OpcLabs.QuickOpc 5.85.0-rev0003 on nuget.org. For troubleshooting your issues, please rebuild with this version, and retest.In order to enable the tracing, you need to make some changes to you project. This can be seen in the example (Client-Instrumentation1), attached in zipped form to this form post. You need to:
  1. Make sure that configuration file, named <yourProgramName>.dll.config, is placed alongside the executable of your program (i.e. in the same directory). In the example project, this file is contained in the project itself, and configured with "Copy to output directory".
  2. The contents of the file should be the same as it is in the example. The file essentially enables various tracing sources and options, and adds a Serilog trace listener.
  3. Your project should contain initialization of the Serilog logger, as in the Program.cs. If the program is long running, make sure you configure a rolling interval, so that a new file is generated from tim to time (e.g. daily). We need the MinimumLevel to be Verbose, and the output template should be as in the example.
  4. For the production run, make sure there is enough disk space - the trace files can be huge. Files are written to the "trace" subdirectory.
File Name: Client-Ins...ion1.zip
File Size:4 KB
  • The following user(s) said Thank You: xpycy001
    18 May 2026 12:22 #14634 by support
    This is to let you know that the version with enhanced tracing is in works, but it is not available yet. It will might be ready next week.
    13 May 2026 09:30 #14628 by support
    it is of course unfortunate that new issues have emerged. We will proceed by extending the tracing/logging as planned, now also with extra focus put on the areas that can be related to these new issues. Please allow some days before we give you the new version and instructions.
    12 May 2026 09:28 #14625 by xpycy001
    Additional notes:
    After switching to version 5.84, four machines were unable to subscribe normally, while the others were functioning normally;
    opc.tcp://10.10.100.121:4840
    opc.tcp://10.10.100.120:4840
    opc.tcp://10.10.100.113:4840
    opc.tcp://10.10.100.112:4840
    After rolling back to version 5.83, all machines can subscribe normally
    Simon.Yu
    vskysoft.com
    2026.5.12 17:29
    12 May 2026 09:24 #14624 by xpycy001
    Hi ,support:
    today deploy and found Problem :
    (1) use ver 5.84.192(2026.1) ,cann't subscrible tags,but OPC_Srv_ConditionChanged.log display "connected" ;
    (2) use ver 5.83 ,can subscrible tags and received valueChanged;(But sometimes the machine fails to reconnect)
    **Attachment document : Bug.zip ** include log files
    Simon.Yu
    vskysoft.com
    2026.5.12 17:24
