OPC AE CustomAttributes
20 Jan 2026 07:18 #14554 by rabbi.mathake
Hi, thank you , yes it works on the latest version.
19 Jan 2026 09:30 #14553 by support
Replied by support on topic OPC AE CustomAttributes
There is built-in trial license that delivers valid data for 30 minutes each time the process is run.
Separate evaluation key is only needed if, for your evaluation, the above time is not sufficient.
The following user(s) said Thank You: rabbi.mathake
19 Jan 2026 09:28 #14552 by rabbi.mathake
No problem kindly share the evaluation key please.
19 Jan 2026 07:51 #14551 by support
There can be a bug in the older version. As I wrote, we no longer support it.
Test the same with the recent version. If ti works, purchase a version upgrade.
19 Jan 2026 05:54 #14550 by rabbi.mathake
Hi,  Unfortunately our current perpetual license is  expired only support up to 5.61, please advise it this might be one of reasons the sdk code provided doesnt work.
################################  I have this in my project. ######################################################
 public void Initialize()
     _logger.LogInformation("AE Client: Initializing AE Client...");
     _fileLogger.Log("AE Client: Initialize()", false, "AE Client");
     _client = new EasyAEClient();
     try
         if (Server != null)
             _hostName = NormalizeHostForOpc(Server.SPrimHostname);
             _nodeName = Server.SPrimHostNodeName;
             _backupHostName = NormalizeHostForOpc(Server.SSecHostname);
             _backupNodeName = Server.SSecHostNodeName;
             failoverMode = Server.FailoverMode;
             AECategoryElementCollection categoryElements;
             try
                 categoryElements = _client.QueryEventCategories(_hostName, _nodeName); // *******************************   I get error on this line ***********************************
             catch (OpcException opcException)
                 Console.WriteLine("*** Failure: {0}", opcException.GetBaseException().Message);
                 return;
             foreach (AECategoryElement categoryElement in categoryElements)
                 Debug.Assert(categoryElement != null);
                 Console.WriteLine("Category {0}:", categoryElement);
                 foreach (AEAttributeElement attributeElement in categoryElement.AttributeElements)
                     Debug.Assert(attributeElement != null);
                     Console.WriteLine("    Information about attribute {0}:", attributeElement);
                     Console.WriteLine("        .AttributeId: {0}", attributeElement.AttributeId);
                     Console.WriteLine("        .Description: {0}", attributeElement.Description);
                     Console.WriteLine("        .DataType: {0}", attributeElement.DataType);
     catch (Exception ex)
         _logger.LogError(ex, "AE Client: Failed to initialize host/node settings.");
         throw;
##############################  He is the error i get. ##############################################################
 System.InvalidOperationException: An item with the same key has already been added. Key: Underflow
       ---> System.ArgumentException: An item with the same key has already been added. Key: Underflow
         at System.Collections.Generic.Dictionary`2.TryInsert(TKey key, TValue value, InsertionBehavior behavior)
         at System.Collections.Generic.Dictionary`2.Add(TKey key, TValue value)
         at System.Collections.ObjectModel.KeyedCollection`2.AddKey(TKey key, TItem item)
         at OpcLabs.EasyOpc.Implementation.NetApi.AlarmsAndEvents.NetApiEasyToOpcNetApiAe.QueryEventCategories(ServerDescriptor serverDescriptor, AEEventType eventTypes)
         at OpcLabs.EasyOpc.Implementation.NetApi.INetApiEasyClientExtension.CheckException(INetApiEasyClient netApiEasyClient, Exception exception, Boolean isOtherMethod)
         at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.TimeoutImposingEasyAEClient.<>c__DisplayClass12_0`1.<ImposeTimeout>b__0()
         at System.Threading.Tasks.Task.InnerInvoke()
         at System.Threading.Tasks.Task.<>c.<.cctor>b__272_0(Object obj)
         at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state)
      --- End of stack trace from previous location ---
         at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot, Thread threadPoolThread)
         at OpcLabs.BaseLib.Extensions.Internal.ExceptionExtension.Rethrow(Exception exception)
         at OpcLabs.BaseLib.Threading.TaskParallelism.Wait(IAsyncResult asyncResult)
         at OpcLabs.BaseLib.Extensions.Internal.ActionExtension.Perform(Action action, Int32 millisecondsTimeout)
         at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.TimeoutImposingEasyAEClient.ImposeTimeout[TResult](Func`1 operationFunction, Int32 millisecondsTimeout)
         at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.ErrorTransformingEasyAEClient.QueryEventCategories(ServerDescriptor serverDescriptor, AEEventType eventTypes)
16 Jan 2026 12:00 - 16 Jan 2026 12:01 #14547 by support
version 5.61 is no longer supported. If you get the same error with the current version, report it here and we will diagnose it.
The information about the attributes is already contained in the result of QueryEventCategories, so the call to QueryCategoryAttributes is not needed. See this example:
opclabs.doc-that.com/files/onlinedocs/OPCLabs-ConnectivitySt...%20an%20event%20attribute.html
Last edit: 16 Jan 2026 12:01 by support.
16 Jan 2026 06:54 #14545 by rabbi.mathake
This message contains secure information
15 Jan 2026 14:05 #14544 by support
This example shows how to specify which custom attributes should be delivered with each event category:
opclabs.doc-that.com/files/onlinedocs/OPCLabs-ConnectivitySt...ieve%20attribute%20values.html
I hope it helps.
15 Jan 2026 12:25 #14543 by rabbi.mathake
