Subscribe to an index of an array
21 Nov 2025 08:31 - 21 Nov 2025 08:34 #14474 by support
I suppose you to mean to an element of an array, not to an index of an array.
OPC UA has such a feature, and QuickOPC supports it. See:
-  opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...ments%20from%20an%20array.html
-  opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...tml#Index%20Range%20Lists.html
The index range can be for a single element, too.
This only works if the OPC UA server actually supports it (not all servers do). OPC Classic does not have a corresponding feature.
Some servers also expose array elements as individual tags.
I hope this helps
Last edit: 21 Nov 2025 08:34 by support.
20 Nov 2025 21:39 #14473 by Cwardltu
Is it possible to subscribe to an index of an array using OPCLabs. if so how?
