Connecting to a PLC with anonymous users turned off
24 Nov 2025 16:51 #14483 by support
I am sorry but I do not understand you.
Are you getting the same results as I reported?
If so, do you expect a different behavior from the software, and what is the behavior you expect?
Note that in my test, when the anonymous logon is disabled in Kepware, I can *not* connect initially. Is that a difference from your observations?
24 Nov 2025 16:47 #14482 by Cwardltu
Yes I found that when i disallowed anon user i would get the same result. Why is that intended. is reconnect not allowed at a anon user?
24 Nov 2025 16:45 - 24 Nov 2025 16:46 #14481 by support
I am confused here. The repro class you sent does not contain any username/password authentication from the client side.
When I run it as is, with "Allow anonymous login" in Kepware turned on, it successfuly connects, and after Reinitialize, it successfuly reconnects, which is expected.
When I run it as is, with "Allow anonymous login" in Kepware turned off, it always fails to connect (with BadUserAccessDenied), which is also expected.
Last edit: 24 Nov 2025 16:46 by support.
24 Nov 2025 16:07 #14480 by Cwardltu
I have added a kepware opf project and a visual studio class that replicates the issue i am having. yes i am subscribing to values that are changing periodically
24 Nov 2025 15:37 #14479 by support
I will try to setup a repro here with Kepware, and let you know the results. I will post here when I know more. Please allow some time for this.
24 Nov 2025 13:31 #14478 by Cwardltu
I am using kepware. I click reinitialize to trigger a reconnect. I do have a 3 subscriptions in this specific test.
22 Nov 2025 09:30 #14477 by support
You are right, it should make no difference whether it is an initial connection or a subsequent connection.
I do not see a problem in your code.
How do you trigger the reconnection, in your tests? E.g. by unplugging the network cable? Or by turning off the PLC? Etc...
And, you simply let you client program run? - Is it doing any subscriptions, or has no subscriptions but is doing periodic/one-time operations such as reads/writes?
21 Nov 2025 14:12 #14476 by Cwardltu
If that were the case wouldnt it be true that the initial connection would be denied aswell? I am only getting the denial when the automatic opclabs reconnection logic is triggered. I am wondering if there is a setting i need to set or something is wrong with my code?
21 Nov 2025 09:53 #14475 by support
The OPC UA server decides whether it allows username/password authentication without a certificate. Most servers do not allow it, for security reasons (without the certificate, the username/password appear unencrypted on the wire and can be eavesdropped on).
From the error you are getting, it looks like that your server either does not all allow username/password authentication without a certificate, or it may allow it but is not currently configured is such a way. Consult the server vendor/documentation if this can be changed.
To resolve the error *with* the use of certificates, you need to go to the server side and make it trust the client certificate from your app (QuickOPC has created one for you).
20 Nov 2025 21:34 #14472 by Cwardltu
Is it possible to connect to a plc using a username and password with anonymous users turned off and not trusted cert configured. I am having issues doing so; initially i connect fine but if i were to reinitialize i start getting issues like the ones below:
I have also added a code snipit below.
x80860000: OPC UA service result - {BadSecureChannelClosed}. The secure channel has been closed. [...]
[Connection Event] Server is UNAVAILABLE - OPC UA service result - {BadSecureChannelClosed}. The secure channel has been closed.
+ The server may have rejected the connection because it does not trust the client (e.g. certificate problem); check the diagnostics on the server side, if possible.
+ The client method called (or event/callback invoked) was 'ServerConditionChanged'.
public void ConnectAsync(string serverURL, string userName = null, string password = null) {     if (string.IsNullOrWhiteSpace(serverURL))         throw new ArgumentNullException(nameof(serverURL));     if (_connected)         Disconnect();     if (_client == null)         _client = new EasyUAClient();     // Accept any certificate     EasyUAClientCore.SharedParameters.EngineParameters.CertificateAcceptancePolicy.AcceptAnyCertificate = true;     _serverUrl = serverURL;     Console.WriteLine("========================================");     Console.WriteLine($"[Connect] Server URL: {serverURL}");     // Simple endpoint creation - let client auto-select best available     Endpoint = new UAEndpointDescriptor(serverURL);     // Add username/password if provided     if (!string.IsNullOrWhiteSpace(userName) && !string.IsNullOrWhiteSpace(password))     {         Console.WriteLine($"[Connect] Username: {userName}");         Endpoint.UserIdentity.UserNameTokenInfo = new OpcLabs.BaseLib.IdentityModel.User.UserNameTokenInfo(userName, password);     }     else     {         Console.WriteLine("[Connect] Authentication: Anonymous");     }     // Try to connect by reading namespaces     _namespaces = new Dictionary<int, string>();     try     {         Console.WriteLine("[Connect] Connecting...");         var nsValues = _client.ReadValue(Endpoint, UAVariableIds.Server_NamespaceArray);         if (nsValues != null && nsValues is string[] namespaceValues)         {             int i = 0;             foreach (var nsValue in namespaceValues)             {                 _namespaces.Add(i++, nsValue);             }             Console.WriteLine($"[Connect] ✓ SUCCESS - {_namespaces.Count} namespaces");         }     }     catch (Exception ex)     {         Console.WriteLine("========================================");         Console.WriteLine("[Connect] ✗ FAILED");         Console.WriteLine($"[Connect] Exception: {ex.GetType().Name}");         Console.WriteLine($"[Connect] Message: {ex.Message}");         if (ex.InnerException != null)         {             Console.WriteLine($"[Connect] Inner: {ex.InnerException.GetType().Name}");             Console.WriteLine($"[Connect] Inner Message: {ex.InnerException.Message}");             if (ex.InnerException.InnerException != null)             {                 Console.WriteLine($"[Connect] Inner-Inner: {ex.InnerException.InnerException.Message}");             }         }         Console.WriteLine("========================================");         throw;     }     _connected = _namespaces.Count > 0;     if (_connected)     {         Console.WriteLine("========================================");     }     // SET UP CONNECTION MONITORING     _connectionMonitoring = _client.GetService<IEasyUAClientConnectionMonitoring>();     if (_connectionMonitoring != null)     {         _connectionMonitoring.ServerConditionChanged += onServerConditionChanged;         Console.WriteLine("Connection monitoring enabled");     }     else     {         Console.WriteLine("Warning: Connection monitoring service not available");     }     _connectionControl = _client.GetService<IEasyUAClientConnectionControl>();     if (_connectionControl == null)     {         Console.WriteLine("Warning: Connection control service not available");     } }
