QuickOPC API License
27 Oct 2025 13:26 #14430 by rabbi.mathake
Replied by rabbi.mathake on topic QuickOPC API License
Thank you, It works on .net 8.
But since we using .Net 6  you dont have QUICKOPC package that works with this version and also able to BrowseNodes and Tags?
27 Oct 2025 13:00 #14429 by support
Replied by support on topic QuickOPC API License
This is a weird error, so at this point I cannot be 100% sure about its cause. But it can be related to the fact that you are using .NET 6.
.NET 6 is no longer supported (neither by Microsoft nor by us). I suggest that you upgrade to .NET 8 or .NET 9, which are the supported runtimes in the latest version.
27 Oct 2025 11:19 #14428 by rabbi.mathake
Here is an  error after upgrading  im using Web API .net 6
System.TypeLoadException: Method 'GetType' in type 'OpcLabs.BaseLib.Exception2' from assembly 'OpcLabs.BaseLib, Version=5.82.423.1, Culture=neutral, PublicKeyToken=6faddca41dacb409' does not have an implementation. at dtm_backend_api.Controllers.DtmLibSrcProcessTagsController.GetOpcTags(Int64 sourceConnectorId) at System.Runtime.CompilerServices.AsyncMethodBuilderCore.Start[TStateMachine](TStateMachine& stateMachine) at dtm_backend_api.Controllers.DtmLibSrcProcessTagsController.GetOpcTags(Int64 sourceConnectorId) at lambda_method9(Closure , Object , Object[] ) at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.AwaitableObjectResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments) at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Awaited|12_0(ControllerActionInvoker invoker, ValueTask`1 actionResultValueTask) at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeNextActionFilterAsync>g__Awaited|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted) at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context) at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted) at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync() --- End of stack trace from previous location --- at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeFilterPipelineAsync>g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted) at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope) at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope) at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger) at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context) at Swashbuckle.AspNetCore.SwaggerUI.SwaggerUIMiddleware.Invoke(HttpContext httpContext) at Swashbuckle.AspNetCore.Swagger.SwaggerMiddleware.Invoke(HttpContext httpContext, ISwaggerProvider swaggerProvider) at Swashbuckle.AspNetCore.SwaggerUI.SwaggerUIMiddleware.Invoke(HttpContext httpContext) at Swashbuckle.AspNetCore.Swagger.SwaggerMiddleware.Invoke(HttpContext httpContext, ISwaggerProvider swaggerProvider) at Microsoft.AspNetCore.Diagnostics.DeveloperExceptionPageMiddleware.Invoke(HttpContext context) HEADERS ======= Accept: text/plain Host: localhost:7246 User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36 :method: GET Accept-Encoding: gzip, deflate, br, zstd Accept-Language: en-US,en;q=0.9 Referer: https://localhost:7246/swagger/index.html sec-ch-ua-platform: "Windows" sec-ch-ua: "Google Chrome";v="141", "Not?A_Brand";v="8", "Chromium";v="141" sec-ch-ua-mobile: ?0 sec-fetch-site: same-origin sec-fetch-mode: cors sec-fetch-dest: empty priority: u=1, i
Error occur on this lines
 var daClient = new EasyDAClient();
 var daElements = daClient.BrowseLeaves(opcUrl, "");
27 Oct 2025 11:11 #14427 by support
My suggestion is as follows:
Use the latest version - which is 5.82, currently.
If it does not work, send me the error you are getting *with that version*.
27 Oct 2025 11:05 #14426 by rabbi.mathake
I want to test browsing of Tag and Nodes in .Net,  I tried QuickOPC 5.8 didnt work ,then i lowered the version still didnt work.
27 Oct 2025 10:01 - 27 Oct 2025 10:01 #14425 by support
You wrote that you wanted to test the latest version. But the version you are running is 5.70, from November 2022.
So do you want to test version from November 2022, or do you actually want to test the latest version?
Bets regards
Last edit: 27 Oct 2025 10:01 by support.
27 Oct 2025 09:52 #14424 by rabbi.mathake
Hi , not really, im trying to browse nodes and tags i get this error.
{ "message": "Failed to browse UA OPC Server: Not allowed to run by the license \"Multipurpose\". You might be running a trial license, and the version of the software you are using is obsolete. To resolve this problem, a) obtain a recent version, or b) ask for an evaluation license key, or c) install a license valid for the current version.\r\nProduct information follows. Component name: \"QuickOPC\", license IDs: \"Multipurpose\", version number: 570, release date: 2022/12/02, trial validity: 397 days, option expression: \"EasyDAClient\".\r\nContext: 0 dropped license(s).", "success": false, "statusCode": 400, "result": null }
27 Oct 2025 09:30 #14423 by support
If you temporarily uninstall your perpetual license for the old version, every version - including the newest ones - will start work in trial mode (30 minutes runtime).
Does that help?
27 Oct 2025 09:16 #14422 by rabbi.mathake
