Live Binding DevExpress support & Sample projects
08 Oct 2025 04:52 #14402 by support
From the screen I have shown in the screenshot, open the solution "C# Client Examples (Visual Studio)".
The projects that use Live Binding for Windows Forms are in that solution are:
- WindowsForms -> LiveBindingDemo
- WindowsForms -> LiveBindingDemo2
- WindowsForms -> UALiveBindingDemo
- WindowsForms -> UALiveBindingDemo2
More about the example projects:
-  opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...les%20for%20OPC%20Classic.html
-  opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...20Architecture%20(OPC-UA).html
Live Binding for WPF is not supported.
07 Oct 2025 17:31 #14400 by Cwardltu
Yeas here is the link to the location:  opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...ta%20(Classic%20and%20UA).html
It says that there was source code in that location but all i see is the application. Also I was looking for the project which has live binding examples. the projects in the image you have shared are projects with general examples. I guess i was hoping for maybe a more detailed response in where excatly to find and example of live binding however if it is not supported I am no longer interested in finding the answer.
07 Oct 2025 08:01 #14399 by support
Attached is a picture of the Launcher program, installed with QuickOPC, which shows where to find the example solutions.
You can also find them on the disk directly - "C:\Program Files (x86)\OPC Labs OPC Studio 2025.1\Examples-NET".
Live Binding for WPF was supported in the past, but is no longer supported in the current version (2025.1). If the documentation for 2025.1 does not make it clear, I would be grateful if you send me the link to the incorrect page, so that we can fix it.
I hope this helps
    06 Oct 2025 19:51 #14398 by Cwardltu
    Throughout the documentation there are hints of sample projects however i am not able to find visual studio projects with actual code. I found examples projects but with out code im afraid its just numbers on a panel to me. are there actual code examples?
    My other questions is the documentation says Live Binding supports wpf application and it mentions it may also work with third party libraries. I wanted to know if it worked with Devexpress and are there examples of this as well?
    thanks
