Read current value on subscription and on reconnection
22 Jul 2025 07:01 #14336 by support
You can set up a logic in your code to ignore them (it would be the first update after an error notification), but QuickOPC does not have an option for it. I still fail to see the usefulness of it, because by ignoring it, you can miss important data .
22 Jul 2025 06:06 #14335 by clyeo
Is there anyway to ignore the data from this -> 'OPC server that sends updates of all monitored items whenever a subscription'
Thanks & Regards
22 Jul 2025 05:52 #14334 by support
QuickOPC does not read the values upon reconnection. It simply subscribes again. It is the OPC server that sends updates of all monitored items whenever a subscription is made. And it is good to do so. Without it, given that there has been a period when the client has not received updates from the server, after reconnection you would have no way of telling whether you have the right data.
After a reconnection and re-establishment of the subscriptions, there is no special handling on the client side, and QuickOPC does not "create" any extra notifications of its own.
22 Jul 2025 05:00 #14333 by clyeo
Hi,Is there any way to disable the behavior where the OPC UA server sends the current value of all subscribed nodes upon a new subscription or after a reconnection?My OPC UA client is deployed in a rather unstable environment, leading to frequent disconnections and reconnections.
This behavior is causing unwanted notifications and events in my system.
Thanks & Regards,
CL
