Browsing Cimplicity UA server - {{BadProtocoIVersionUnsupported}
15 Jul 2025 07:04 #14328 by micham
Thank you. We will check it.
15 Jul 2025 05:04 #14327 by support
This is most likely user error. The discovery URL passed to us is "ISRCIMPB:51800". That's wrong. "ISRCIMPB" looks like machine name. The correct discovery URL should then be something like "opc.tcp://ISRCIMPB:51800".
I will need to see the screenshots showing what has been done that lead to this error.
14 Jul 2025 16:04 - 14 Jul 2025 16:05 #14325 by micham
Our customer is trying to browse for OPC UA items using Cimplicity OPC UA server. He is getting the following error
OPC UA service result - {BadProtocoIVersionUnsupported}. Unsupported transport profile for scheme isrcimpb.
Exception details:
Exceptions
Data: ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: OpcLabs.{4D759503}
    OpcLabs.EasyOpc.UA.Engine.UAEngineException: UA SDK error (Opc.UA.ServiceResult=0x80BE0000) in 'static DiscoveryClient.Create'. OPC UA service result - {BadProtocolVersionUnsupported}. Unsupported transport profile for scheme isrcimpb. Unsupported transport profile for scheme isrcimpb.
    + The error occurred when preselecting an endpoint for discovery URL "ISRCIMPB:51800".
    + Connection attempt #4; last connected at 01/01/0001 00:00:00 (local); unconnected for 00:22:04.8900000.
    + Diagnostic OPCUA0009: The OPC endpoint scheme used, "isrcimpb", is not a standard OPC UA (client-server) scheme.
    + The client method called (or event/callback invoked) was 'BrowseMultiple[1]'. ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {BadProtocolVersionUnsupported}. Unsupported transport profile for scheme isrcimpb. Unsupported transport profile for scheme isrcimpb.
    Activity Trace:
        Following (2) events were gathered during the action on activity ID [31], in the order of first occurrence:
          SDK trace: The transport binding isrcimpb is unsupported.
          Exception: {Opc.Ua.ServiceResultException} Unsupported transport profile for scheme isrcimpb.
            ((31, 1), Opc.Ua.TraceEventArgs)
            ((31, 1), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
        c3c0e69e-bf8f-4bfa-8e93-816783737e55: 31
        8970fe52-aaa4-40f7-9a6e-74cdcee56724: static DiscoveryClient.Create
    Error Code: 1
    Error Id: OpcLabs.UAEngine=1
    InnerException: OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {BadProtocolVersionUnsupported}. Unsupported transport profile for scheme isrcimpb. Unsupported transport profile for scheme isrcimpb.
        Data: OpcLabs.EasyOpc.UA.Implementation.ErrorEnhancingEasyUAClient.Processed: True
        Error Id: Opc.UA.ServiceResult=0x80BE0000
        Help Link:
        Internal Code: 2159935488
        Message: OPC UA service result - {BadProtocolVersionUnsupported}. Unsupported transport profile for scheme isrcimpb. Unsupported transport profile for scheme isrcimpb.
        Service Result: BadProtocolVersionUnsupported
            Additional Info:
            Description: Unsupported transport profile for scheme isrcimpb.
            Inner Result:
            Message: Unsupported transport profile for scheme isrcimpb.
            Qualified Symbolic ID:
                Expanded Text:
                Is Null: True
                Is Standard: True
                Name:
                Namespace Index: 0
                Namespace URI:
                Namespace URI String:
                Standard Name:
            Status Code: BadProtocolVersionUnsupported
                Code Bits: 32958
                Code Bits Symbol: BadProtocolVersionUnsupported
                Condition: 190
                Description: The applications do not have compatible protocol versions.
                Flag Bits: 0
                Has Data Value Info: False
                Info Type: NotUsed
                Internal Value: 2159935488
                Is Bad: True
                Is Good: False
                Is Uncertain: False
                Limit Info: None
                Overflow: False
                Semantics Changed: False
                Severity: BadOrFailure
                Status Info: Error
                Structure Changed: False
            Text: {BadProtocolVersionUnsupported}. Unsupported transport profile for scheme isrcimpb.
        Service Target Site: Opc.Ua.ITransportChannel CreateUaBinaryChannel(Opc.Ua.ApplicationConfiguration, Opc.Ua.EndpointDescription, Opc.Ua.EndpointConfiguration, System.Security.Cryptography.X509Certificates.X509Certificate2, System.Security.Cryptography.X509Certificates.X509Certificate2Collection, Opc.Ua.IServiceMessageContext)
            DeclaringType: Opc.Ua.UaChannelBase
            Module: Opc.Ua.Core.dll
                Assembly: Opc.Ua.Core, Version=1.4.372.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8
                CustomAttributes:
                FullyQualifiedName: C:\Program Files (x86)\Control-See\UCME-OPC\BIN\Opc.Ua.Core.dll
                MDStreamVersion: 131072
                MetadataToken: 1
                ModuleVersionId: 2f574461-cda9-4e81-90f8-5143a4831ede
                ScopeName: Opc.Ua.Core.dll
        Source: Opc.Ua.Core
        Stack Trace:
               at Opc.Ua.UaChannelBase.CreateUaBinaryChannel(ApplicationConfiguration configuration, EndpointDescription description, EndpointConfiguration endpointConfiguration, X509Certificate2 clientCertificate, X509Certificate2Collection clientCertificateChain, IServiceMessageContext messageContext)
               at Opc.Ua.DiscoveryChannel.Create(Uri discoveryUrl, EndpointConfiguration endpointConfiguration, IServiceMessageContext messageContext, X509Certificate2 clientCertificate)
               at OpcLabs.EasyOpc.UA.Toolkit.Sdk.ToolkitDiscoveryClient.Create(Uri discoveryUrl, ApplicationConfiguration sdkApplicationConfiguration, EndpointConfiguration configuration, Action`2 setupTransportChannel)
               at OpcLabs.EasyOpc.UA.Toolkit.Client.UADiscoverySessionBase.<>c__DisplayClass2_0.<CreateSdkDiscoveryClient>b__3()
        TargetSite:
    Message:
    Source:
    Stack Trace:
        == Activity Trace ==
    TargetSite:
Source:
TargetSite:
Browsing with UA Expert works fine. Any idea what may cause this issue?
We are using the Nuget Package 5.80.192. OPC Studio 2024.1 (5.80.278.1)
  • Last edit: 14 Jul 2025 16:05 by micham.
