WriteMultipleItemValues gets stuck
14 May 2025 05:32 #14181 by KrisSik
Thank you for the response.
Right now I am testing my app with disabled boxers, and it's running fine for a few days already. If this will fail, I will try your suggestion and let you know.
Kristian
13 May 2025 09:43 #14180 by support
Oh, I see, thank you.
You have provided the right stack trace. The issue is that many of the frames are optimized away, which confused me at first, and also makes the diagnostics much harder, because the part I am looking for is not displayed.
Can you please try to disable the OPC DA optimizer ( opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...html#OPC%20DA%20Optimizer.html )
This has to be done on every instance of EasyDAClient *before* any actuals OPC operations are called:
            client.InstanceParameters.PluginSetups[EasyDAUriStrings.OptimizerPlugin].Enabled = false;
There is a chance that this helps.
12 May 2025 08:58 #14178 by KrisSik
Please check this stack trace:
System.Linq.Parallel.OrderPreservingPipeliningMergeHelper`2+OrderedPipeliningMergeEnumerator[[System.__Canon, System.Private.CoreLib],[System.Int32, System.Private.CoreLib]].TryWaitForElement(Int32, System.Linq.Parallel.Pair`2<Int32,System.__Canon> ByRef)+bc     System.Linq.Parallel.OrderPreservingPipeliningMergeHelper`2+OrderedPipeliningMergeEnumerator[[System.__Canon, System.Private.CoreLib],[System.Int32, System.Private.CoreLib]].MoveNext()+5d     System.Linq.Parallel.QueryOpeningEnumerator`1[[System.__Canon, System.Private.CoreLib]].MoveNext()+36     System.Collections.Generic.List`1[[System.__Canon, System.Private.CoreLib]]..ctor(System.Collections.Generic.IEnumerable`1<System.__Canon>)+1f2     System.Linq.Enumerable.ToList[[System.__Canon, System.Private.CoreLib]](System.Collections.Generic.IEnumerable`1<System.__Canon>)+9a     OpcLabs.EasyOpc.DataAccess.Internal.DelegatingEasyDAClient.WriteMultipleItemValues(OpcLabs.EasyOpc.DataAccess.OperationModel.DAItemValueArguments[])+12c     OpcLabs.BaseLib.Threading.Extensions.IParallelismExtension+<>c__DisplayClass4_1`3[[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib]].<GroupSelect>b__1()+e0     OpcLabs.BaseLib.Threading.TaskParallelism.Perform(System.Collections.Generic.IEnumerable`1<System.Action>)+96     OpcLabs.BaseLib.Threading.Extensions.IParallelismExtension.GroupSelect[[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib]](OpcLabs.BaseLib.Threading.IParallelism, System.Collections.Generic.IEnumerable`1<System.__Canon>, System.Func`2<System.__Canon,System.__Canon>, System.Func`3<System.__Canon,System.Collections.Generic.IEnumerable`1<System.__Canon>,System.__Canon[]>, System.Collections.Generic.IEqualityComparer`1<System.__Canon>)+24d     OpcLabs.BaseLib.Threading.Extensions.IParallelismExtension.GroupSelect[[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib]](OpcLabs.BaseLib.Threading.IParallelism, System.Collections.Generic.IEnumerable`1<System.__Canon>, System.Func`2<System.__Canon,System.__Canon>, System.Func`3<System.__Canon,System.Collections.Generic.IEnumerable`1<System.__Canon>,System.__Canon[]>)+cf     OpcLabs.EasyOpc.DataAccess.Implementation.EasyDAClientCompositor.WriteMultipleItemValues(OpcLabs.EasyOpc.DataAccess.OperationModel.DAItemValueArguments[])+ca     MyApplication.Opc.Connection.OpcClient.WriteItems(System.Collections.Generic.IEnumerable`1<MyApplication.Opc.Data.WriteItemRequest>)+7a6
Basically my WriteItems implementation is:
        public IReadOnlyCollection<WriteItemResponse> WriteItems(IEnumerable<WriteItemRequest> requests)         {             var requestsList = requests.ToList();             _logger.Debug(                 "Writing multiple items. Item: {@Item}",                 requestsList);             OperationResult[] writeResults =                 _opcClient.[b]WriteMultipleItemValues[/b](requestsList.Select(r => new DAItemValueArguments(_opcServer, new DAItemDescriptor(r.ItemId), r.Value, r)).ToArray());             _logger.Debug("Stopped writing items [{FirstItem},..].", requestsList.First());             return writeResults.Select(Map).ToList();         }
12 May 2025 08:25 #14176 by support
Thank you,
but somehow this is still missing the initiating call and many part below. Perhaps it was done on another thread? Can you inspect the list of threads, and find the one that has *your* call to WriteMultipleItemValues? It is not in this call stack.
12 May 2025 04:55 #14175 by KrisSik
I missed "[]" in my topic message. Please check out this stack trace:System.Linq.Parallel.OrderPreservingPipeliningMergeHelper`2+OrderedPipeliningMergeEnumerator[[System.__Canon, System.Private.CoreLib],[System.Int32, System.Private.CoreLib]].TryWaitForElement(Int32, System.Linq.Parallel.Pair`2<Int32,System.__Canon> ByRef)+bc  System.Linq.Parallel.OrderPreservingPipeliningMergeHelper`2+OrderedPipeliningMergeEnumerator[[System.__Canon, System.Private.CoreLib],[System.Int32, System.Private.CoreLib]].MoveNext()+5d  System.Linq.Parallel.QueryOpeningEnumerator`1[[System.__Canon, System.Private.CoreLib]].MoveNext()+36  System.Collections.Generic.List`1[[System.__Canon, System.Private.CoreLib]]..ctor(System.Collections.Generic.IEnumerable`1<System.__Canon>)+1f2  System.Linq.Enumerable.ToList[[System.__Canon, System.Private.CoreLib]](System.Collections.Generic.IEnumerable`1<System.__Canon>)+9a  OpcLabs.EasyOpc.DataAccess.Internal.DelegatingEasyDAClient.WriteMultipleItemValues(OpcLabs.EasyOpc.DataAccess.OperationModel.DAItemValueArguments[])+12c  OpcLabs.BaseLib.Threading.Extensions.IParallelismExtension+<>c__DisplayClass4_1`3[[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib]].<GroupSelect>b__1()+e0  OpcLabs.BaseLib.Threading.TaskParallelism.Perform(System.Collections.Generic.IEnumerable`1<System.Action>)+96  OpcLabs.BaseLib.Threading.Extensions.IParallelismExtension.GroupSelect[[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib]](OpcLabs.BaseLib.Threading.IParallelism, System.Collections.Generic.IEnumerable`1<System.__Canon>, System.Func`2<System.__Canon,System.__Canon>, System.Func`3<System.__Canon,System.Collections.Generic.IEnumerable`1<System.__Canon>,System.__Canon[]>, System.Collections.Generic.IEqualityComparer`1<System.__Canon>)+24d  OpcLabs.BaseLib.Threading.Extensions.IParallelismExtension.GroupSelect[[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib]](OpcLabs.BaseLib.Threading.IParallelism, System.Collections.Generic.IEnumerable`1<System.__Canon>, System.Func`2<System.__Canon,System.__Canon>, System.Func`3<System.__Canon,System.Collections.Generic.IEnumerable`1<System.__Canon>,System.__Canon[]>)+cf  OpcLabs.EasyOpc.DataAccess.Implementation.EasyDAClientCompositor.WriteMultipleItemValues(OpcLabs.EasyOpc.DataAccess.OperationModel.DAItemValueArguments[])+ca
12 May 2025 04:50 #14174 by KrisSik
It is there - OpcLabs.EasyOpc.DataAccess.Implementation.EasyDAClientCompositor.WriteMultipleItemValues(OpcLabs.EasyOpc.DataAccess.OperationModel.DAItemValueArguments[]).
Kristian
09 May 2025 05:52 #14167 by support
Is this the whole call stack you can get? It appears incomplete. It should contain at least the top-level "Write" call you are making, plus everything below.
07 May 2025 09:18 - 07 May 2025 09:25 #14164 by KrisSik
I encoutered an issue with the WriteMultipleItemValues method, which gets stuck when interacting with the OPC DA server. I can see this issue in both the logs and dump files. I captured 2 dump files - about 5 minutes apart after the application got stuck - and the same thread with the same stack trace is hanging in both:
System.Linq.Parallel.OrderPreservingPipeliningMergeHelper`2+OrderedPipeliningMergeEnumerator[[System.__Canon, System.Private.CoreLib],[System.Int32, System.Private.CoreLib]].TryWaitForElement(Int32, System.Linq.Parallel.Pair`2<Int32,System.__Canon> ByRef)+bc     System.Linq.Parallel.OrderPreservingPipeliningMergeHelper`2+OrderedPipeliningMergeEnumerator[[System.__Canon, System.Private.CoreLib],[System.Int32, System.Private.CoreLib]].MoveNext()+5d     System.Linq.Parallel.QueryOpeningEnumerator`1[[System.__Canon, System.Private.CoreLib]].MoveNext()+36     System.Collections.Generic.List`1[[System.__Canon, System.Private.CoreLib]]..ctor(System.Collections.Generic.IEnumerable`1<System.__Canon>;)+1f2     System.Linq.Enumerable.ToList[[System.__Canon, System.Private.CoreLib]](System.Collections.Generic.IEnumerable`1<System.__Canon>;)+9a     OpcLabs.EasyOpc.DataAccess.Internal.DelegatingEasyDAClient.WriteMultipleItemValues(OpcLabs.EasyOpc.DataAccess.OperationModel.DAItemValueArguments)+12c     OpcLabs.BaseLib.Threading.Extensions.IParallelismExtension+<>c__DisplayClass4_1`3[[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib]].<GroupSelect>b__1()+e0     OpcLabs.BaseLib.Threading.TaskParallelism.Perform(System.Collections.Generic.IEnumerable`1<System.Action>;)+96     OpcLabs.BaseLib.Threading.Extensions.IParallelismExtension.GroupSelect[[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib]](OpcLabs.BaseLib.Threading.IParallelism, System.Collections.Generic.IEnumerable`1<System.__Canon>, System.Func`2<System.__Canon,System.__Canon>, System.Func`3<System.__Canon,System.Collections.Generic.IEnumerable`1<System.__Canon>,System.__Canon>, System.Collections.Generic.IEqualityComparer`1<System.__Canon>;)+24d     OpcLabs.BaseLib.Threading.Extensions.IParallelismExtension.GroupSelect[[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib],[System.__Canon, System.Private.CoreLib]](OpcLabs.BaseLib.Threading.IParallelism, System.Collections.Generic.IEnumerable`1<System.__Canon>, System.Func`2<System.__Canon,System.__Canon>, System.Func`3<System.__Canon,System.Collections.Generic.IEnumerable`1<System.__Canon>,System.__Canon>;)+cf     OpcLabs.EasyOpc.DataAccess.Implementation.EasyDAClientCompositor.WriteMultipleItemValues(OpcLabs.EasyOpc.DataAccess.OperationModel.DAItemValueArguments)+ca
The EasyDAClient.InstanceParameters.Timeouts.WriteItem is set to 2000ms, but seems to be not respected in this case.
I've also tested several versions of OpcLabs.QuickOpc, and while the number of items is identical, there is a difference in how quickly the issue reproduces:
- for versions 5.81.485 and 5.80.347 it takes a few minutes (sometimes a few seconds) of application running
- for version 5.63.246 it takes from a few hours to a few days of application running
My application is using .NET 6.
Kristian
Last edit: 07 May 2025 09:25 by KrisSik.
