Order of operations in IEasyUAClient.WriteMultiple
09 Apr 2025 19:53 #13545 by support
In most cases, the current implementation will issue a single OPC Write call in which the arguments are ordered in the same way your code has specified, but this behavior should be considered an implementation detail and *is not guaranteed*, intentionally.
More about non-guarantees:  kb.opclabs.com/Non-guarantees
If you need ordered Write-s, you should issue separate calls, in that order.
09 Apr 2025 19:21 #13544 by aris
Does
IEasyUAClient.WriteMultiple(requests)
ensure that the write operations are performed in the same order as they appear in the
requests
array, or does it only guarantee that the results are returned in the same order as the requests?
