Licence not recogniced using "RegisterManagedResource"
27 Feb 2025 12:49 #13435 by support
I agree that this should work.
Can you please attach a handler to the static EasyUAClient.LogEntry event (or EasyDAClient, if that's what you are using), and capture the messages you get, and post them here? There should be one that has more details about why the license has not been found.
27 Feb 2025 09:23 #13432 by tobias.kettner@hirschvogel.com
I am upgrading my development from an old QuickOPC 5.59 to the actual one 5.81. We bought a new Licence for this.
1. Using just the new licence txt file in our old project works fine. Only change was replacing the licence file name.  (.NET Core 3.1)
2. Updated my development to .NET 8 and new QuickOPC 5.81 and tried to use the new licence file. Nothing else was changed.
-> I end up with a Trial Licence
Embedding the resource is done correctly, because any change to the Filename oder Resource Name gives me an exeption when loading it with "RegisterManagedResourceWithExistenceCheck".
When I install the Licence using the Licence Manager it is working, but this is not the way I want to do it with all the clients.
Thank you for your Help.
Tobias Kettner
