Runt time is over the limit in license "Multipurpose".....
16 Feb 2025 20:13 #13397 by support
License key sent by email.
And here is the doc to the license key embedding: opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...esource%20License%20Store.html .
16 Feb 2025 16:42 #13396 by micham
Thank you for your answer.
Currently we use the LMConsole program to activate the license.
Maybe it is a better idea to embed the license within the application. Can you send me an example how to do it?
Can you please send me my license key for version 2024.1?
16 Feb 2025 14:26 #13395 by support
This license key does not cover version 2024.1. For this version, you need the one with S/N 1999320511.
Are you embedding the license key within the project, or are the customers installing it separately using the License Manager? If the proper license key is embedded with the application, no additional steps are necessary by the end customer, and this kind of problem cannot/should not happen.
16 Feb 2025 13:37 #13394 by micham
Our customer is getting the following error:
I'm using Quick OPC Nuget Package version 5.80.182.
OPC Studio version 2024.1 (5.80.278.1) is installed.
The Key-Permanent-WebForm-1999320511-20231222.txt file was provide in Nov-20-2023. Is it the correct license?
Note: I don't see the problem on my computer.
