error after SubscribeEvent with server with open62541.dll
05 Feb 2025 16:22 #13360 by Filippi
I confirm it well working for UaExpert and Traeger .net sdk client
05 Feb 2025 16:18 #13359 by support
The first callback is special and indicates a successful connection to the server. It is generated on the client side. So that's fine with both servers.
The error reported with one of the servers comes from the server itself. Do you know for sure that the server can generate events like this? Have you verified it with some other OPC UA client?
05 Feb 2025 14:59 #13358 by Filippi
First CallBack
Second CallBack
    05 Feb 2025 14:57 - 05 Feb 2025 16:14 #13357 by Filippi
    public static void MainSubScription() { UAEndpointDescriptor endpointDescriptor = "opc.tcp://localhost:4840"; // Instantiate the client object and hook events. var client = new EasyUAClient(); client.EventNotification += client_EventNotification; Console.WriteLine("Subscribing..."); client.SubscribeEvent(endpointDescriptor, UAObjectIds.Server, 1000); Console.WriteLine("Processing event notifications for 30 seconds..."); //System.Threading.Thread.Sleep(30 * 1000); Console.WriteLine("Unsubscribing..."); //client.UnsubscribeAllMonitoredItems(); Console.WriteLine("Waiting for 5 seconds..."); //System.Threading.Thread.Sleep(5 * 1000); Console.WriteLine("Finished."); } private static void client_EventNotification(object sender, EasyUAEventNotificationEventArgs e) { // Display the event. if (e.EventData is null) { Console.WriteLine(e.ErrorMessage); return; } Console.WriteLine("All fields:"); foreach (KeyValuePair<UAAttributeField, ValueResult> pair in e.EventData.FieldResults) { UAAttributeField attributeField = pair.Key; ValueResult valueResult = pair.Value; Console.WriteLine(" {0} -> {1}", attributeField, valueResult); } }
    Last edit: 05 Feb 2025 16:14 by support. Reason: formatting
    05 Feb 2025 14:29 #13356 by support
    It is not clear to me what are you trying to achieve. Can you post the code that show how you subscribe?
    05 Feb 2025 13:34 #13355 by Filippi
    After call the Subscrition event the callback has been called 2 times:
    1. With a Success Event Args
    2. with this error (see also the attachment)
    (OPC UA service result - {BadNodeIdUnknown}. The node id refers to a node that does not exist in the server address space.
    + The node descriptor used was: NodeId="Server".
    + The client method called (or event/callback invoked) was 'EventNotification'.)
    In case of other Server OPC-UA I callback has been called 2 times:
    2. With a Audit Initialized
    I know I'm not so detailed in my report but the situation is a little bit confusing for me ...
    Thanks for any help
