Timeout during WriteMultipleItemValues
16 Jan 2025 21:47 #13342 by aris
I subscribed to logs with
EasyDAClient.LogEntry += EasyDAClientOnLogEntry;
. I do see some log entries when I apply the license but I don't see any log entries when this error happens. Any suggestions what next steps I can take?
10 Dec 2024 09:10 #13311 by support
09 Dec 2024 20:31 #13310 by aris
I'm using "App_Web_OpcLabs.EasyOpcClassicRaw.x86" version 5.63.246.1.
Once in a while I get the following error when using WriteMultipleItemValues. What can do to resolve/debug and understand what's causing it. The message suggests to Check the event log for queue overflow errors, where are the logs?:
Write not completed. This error indicates that it could not be verified that the requested write operation was completed during the timeout period. It is possible that the write operation will actually succeed or fail, but later. Increase the timeout period if you want to obtain positive or negative indication of the operation outcome. Other reason for this error may be that under heavy loads, topic request or response queue is overflowing. Check the event log for queue overflow errors (if event logging is supported by the product and enabled). + The client method called (or event/callback invoked) was 'WriteMultipleItemValues[4]'.
