OPC UA in Linux
07 Dec 2024 08:54 #13308 by support
Replied by support on topic OPC UA in Linux
Windows registry is just one of the possible places where license key can be stored. On Linux, you will either embed the license key into your application, or place it in the file system. All this is explained in the User's Guide.
Links:
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...html#Licensing%20Elements.html
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...ml#File%20License%20Store.html
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...esource%20License%20Store.html
I hope this helps
07 Dec 2024 00:34 #13307 by Aaron
OPC UA in Linux was created by Aaron
I'm trying to connect to an OPC using EasyUAClient in C# on Linux, but it seems that the license serial number gets its value from:
[HKEY_LOCAL_MACHINE\SOFTWARE\Licensing\QuickOpc\Multipurpose] (Only available on Windows)
What should I do?
