Issues reading from a NodeId using special characters with the escape character
14 Nov 2024 09:21 #13275 by support
Please post here the URL where the documentation tells you about such escaping. Either the documentation is wrong, or you are misinterpreting it. There is no specific escaping needed for the identifier part of the node Id.
Assuming that what you want is a node Id with namespace index 2 and a string identifier "Data Type Examples.8 Bit Device.K Registers.Boole:an4", it can be constructed like
new UANodeId("ns=2; s=Data Type Examples.8 Bit Device.K Registers.Boole:an4")
If you have the namespace index and the identifier separately already, there is no need to bother with formatting the node Id as text. Simply use
new UANodeId(2, "Data Type Examples.8 Bit Device.K Registers.Boole:an4")
Have you seen this example?:
opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...%20Create%20a%20node%20ID.html
13 Nov 2024 16:25 #13274 by Cwardltu
I am getting the errors reading tag with special characters. Is this supported. According to the doc I am using the correct escape character &
Node Id = ns=2; s=Data Type Examples.8 Bit Device.K Registers.Boole&:an4
Time to create page: 0.447 seconds
