Impossible to install/use QuickOpc (EasyUACLient) in Visual Studio
06 Sep 2024 07:50 #13144 by _laurent1988_
I tried to clean some unnecessary references and/or re-referenced them, and at the end, everything is OK.
Not totally sure what was the reference(s) causing the issue, but it was definitely not due to QuickOPC side.
Thank you very much for the help, and feel free to either delete or keep this thread which may be out of specifically QuickOPC-issues relative discussions.
Laurent
30 Aug 2024 12:36 #13087 by support
Make sure you delete all unnecessary assembly references from your project.
30 Aug 2024 12:32 #13086 by _laurent1988_
OK, I have cleaned the package mapping, and the QuickOPC packages have been installed successfully !
All packages (including dependant assemblies) are now mapping to nuget.org.
But some dependencies issues / versions conflicts still remain.
At runtime, when creating an EasyUAClient, this exception still raises :
System.TypeInitializationException
HResult=0x80131534
Message=Une exception a été levée par l'initialiseur de type pour 'OpcLabs.EasyOpc.UA.EasyUAClientCore'.
Source=OpcLabs.EasyOpcUA
Arborescence des appels de procédure :
à OpcLabs.EasyOpc.UA.EasyUAClientCore..ctor()
à OpcLabs.EasyOpc.UA.EasyUAClient..ctor()
à Remote.Remote..ctor() dans C:\Users\U\Documents\Visual Studio 2022\Projects\STAN\Remote\OPC_UA\OPC_UA.cs :ligne 19
Cette exception a été levée à l'origine dans cette pile des appels :
[Code externe]
Exception interne 1 :
FileNotFoundException : Impossible de charger le fichier ou l'assembly 'System.Diagnostics.DiagnosticSource, Version=6.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51' ou une de ses dépendances. Le fichier spécifié est introuvable.
Regarding the version conflicts, the huge VS error list shows the messages included in the enclosed text file.
In the meantime, I've tried your PicoOPC UA component and it seems to work well in my project. No exception, no message, etc.
This tiny component would probably offer 99% of my needs and maybe we could talk about a licence transfering or something like that, if I eventually can't use the QuickOPC ?
Laurent
30 Aug 2024 11:16 #13083 by support
You have configured your package source mappings in such a way that only Microsoft and nuget packages can be downloaded.
Learn about it: learn.microsoft.com/en-us/nuget/consume-packages/package-source-mapping .
You can either turn off the package mapping, or you need to configure it in such a way that OpcLabs.* packages, but also all dependent packages, are mapped to nuget.org.
30 Aug 2024 10:00 #13082 by _laurent1988_
Hello again,
I've tried something different : switching from Packages.Config to PackageReference in the nuget packages manager options, and something different happens : a long download and installation process occurs, but in the end, it fails, with these raised messages :
Restauration des packages pour C:\Users\U\Documents\Visual Studio 2022\Projects\STAN\Remote\OPC_UA\OPC_UA.csproj...
NU1100: Impossible de résoudre 'Microsoft.Extensions.Caching.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Caching.Memory (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Binder (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Json (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Hosting (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Hosting.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.PlatformAbstractions (>= 1.1.0)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Win32.Registry (>= 5.0.0)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Http (>= 2.1.34)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel (>= 2.1.3)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Core (>= 2.1.25)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Https (>= 2.1.3)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets (>= 2.1.40)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Bcl.HashCode (>= 1.1.1)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Logging.Abstractions (>= 6.0.4)' pour '.NETFramework,Version=v4.7.2'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Caching.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Caching.Memory (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Binder (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Json (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Hosting (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Hosting.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.PlatformAbstractions (>= 1.1.0)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Win32.Registry (>= 5.0.0)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Http (>= 2.1.34)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel (>= 2.1.3)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Core (>= 2.1.25)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Https (>= 2.1.3)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets (>= 2.1.40)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Bcl.HashCode (>= 1.1.1)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Logging.Abstractions (>= 6.0.4)' pour '.NETFramework,Version=v4.7.2/win'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Caching.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Caching.Memory (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Binder (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Json (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Hosting (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Hosting.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.PlatformAbstractions (>= 1.1.0)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Win32.Registry (>= 5.0.0)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Http (>= 2.1.34)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel (>= 2.1.3)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Core (>= 2.1.25)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Https (>= 2.1.3)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets (>= 2.1.40)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Bcl.HashCode (>= 1.1.1)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Logging.Abstractions (>= 6.0.4)' pour '.NETFramework,Version=v4.7.2/win-arm64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Caching.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Caching.Memory (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Binder (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Json (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Hosting (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Hosting.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.PlatformAbstractions (>= 1.1.0)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Win32.Registry (>= 5.0.0)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Http (>= 2.1.34)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel (>= 2.1.3)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Core (>= 2.1.25)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Https (>= 2.1.3)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets (>= 2.1.40)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Bcl.HashCode (>= 1.1.1)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Logging.Abstractions (>= 6.0.4)' pour '.NETFramework,Version=v4.7.2/win-x64'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Caching.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Caching.Memory (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Binder (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Configuration.Json (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Hosting (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Hosting.Abstractions (>= 6.0.0)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.PlatformAbstractions (>= 1.1.0)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Win32.Registry (>= 5.0.0)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Http (>= 2.1.34)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel (>= 2.1.3)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Core (>= 2.1.25)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Https (>= 2.1.3)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets (>= 2.1.40)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Bcl.HashCode (>= 1.1.1)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
NU1100: Impossible de résoudre 'Microsoft.Extensions.Logging.Abstractions (>= 6.0.4)' pour '.NETFramework,Version=v4.7.2/win-x86'. PackageSourceMapping est activé, les sources suivantes n'ont pas été prises en compte : nuget.org.
CACHE api.nuget.org/v3/vulnerabilities/index.json
CACHE api.nuget.org/v3-vulnerabilities/2024.08.29.05.32.17/vulnerability.base.json
CACHE api.nuget.org/v3-vulnerabilities/2024.08.29.05.32.17/2024.08...2.19/vulnerability.update.json
Échec de la restauration du package. Restauration des modifications du package pour 'OPC_UA'.
Temps écoulé : 00:00:00.4204593
========== Fin ==========
30 Aug 2024 08:58 #13081 by _laurent1988_
You should *not* reference the assemblies under C:\Program Files (x86)\OPC Labs OPC Studio 2024.1\Components\OpcLabs.QuickOpc\net472 . No wonder it does not work. It will never work. It is not what the documentation tells you to do. Forget it. You must always reference the NuGet packages.
I gave it a try when the nuget packages installation failed.
1. The Launcher has an "About" button. What version of QuickOPC does it report?
Version 2024.1 (5.80.347.1)
By the way, my Windows 10 version is 10.0.19045 build 19045
2. It looks like that you have added C:\Program Files (x86)\OPC Labs OPC Studio 2024.1\NuGetPackages to your NuGet package sources. Why? This is something that is only needed in very special situations, and certainly not in your case. Remove this package source, and retest. Do not add it later again.
As my pro computer was not connected to internet when I started installing packages, I thought I had to point to this folder instead. Then I connect to the web to see what would happen by using the nuget.org package source. Removing this local package source and using only the nuget.org source does not fix the issue anyway.
3. In Visual Studio, open the NuGet Package Manager (GUI). Switch to the Browse tab, and make sure that the Package source (upper right corner) is set to "nuget.org". Type "OpcLabs" into the Search box. Post here the screenshot of the NuGet Package Manager that you get after doing this.
Here enclosed is the screenshot.
Clicking to the install button raised this message :
Le package « OpcLabs.QuickOpc 5.80.347 » est introuvable dans la ou les sources principales suivantes : « api.nuget.org/v3/index.json ». Vérifiez que toutes vos sources de package en ligne sont disponibles (OU) que l'ID de package et la version sont spécifiés correctement.
Enclosed the nuget packages manager with its options :
Laurent
    30 Aug 2024 08:15 - 30 Aug 2024 08:15 #13080 by support
    Thank you for all the information. I have some more questions - this will take more rounds, please be patient, but I believe we will get it resolved.
    The Visual Studio version is OK.
    NuGet packages are always used. Using the Setup just installs additional tools, examples, demos, and the VS extension for visual design (including the Toolbox icons).
    Here are the additional questions:
    Thank you, and best regards
    Last edit: 30 Aug 2024 08:15 by support.
    30 Aug 2024 07:52 #13079 by _laurent1988_
    When directly referencing the C:\Program Files (x86)\OPC Labs OPC Studio 2024.1\Components\OpcLabs.QuickOpc\net472 dll's :
    The project compiles but the following exception is raised at runtime, when passing on the EasyUAClient opcClient = new EasyUAClient(); (*):
    Even if I referenced the System.Diagnostics.DiagnosticSource, Version=6.0.0.0 in the project.
    Laurent
    30 Aug 2024 07:46 #13078 by _laurent1988_
    1- Visual Studio version :
    Microsoft Visual Studio Community 2022
    Version 17.11.2
    VisualStudio.17.Release/17.11.2+35222.181
    Microsoft .NET Framework
    Version 4.8.09037
    Version installée : Community
    Visual C++ 2022 00482-90000-00000-AA579
    Microsoft Visual C++ 2022
    Adaptateur de test pour Boost.Test 1.0
    Permet d'utiliser les outils de test de Visual Studio avec des tests unitaires écrits pour Boost.Test. Les conditions d'utilisation et les mentions tierces sont disponibles dans le répertoire d'installation de l'extension.
    ASP.NET and Web Tools 17.11.230.51983
    Azure Functions and Web Jobs Tools 17.11.230.51983
    Common Azure Tools 1.10
    Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
    Gestionnaire de package NuGet 6.11.0
    Gestionnaire de package NuGet dans Visual Studio. Pour plus d'informations sur NuGet, visitez docs.nuget.org/
    GitHub Copilot 0.2.1634.3922
    GitHub Copilot est un programmeur de paires d’intelligence artificielle qui vous permet d’écrire du code plus rapidement et avec moins de travail.
    Microsoft JVM Debugger 1.0
    Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
    Outils Azure App Service v3.0.0 17.11.230.51983
    Outils C# 4.11.0-3.24376.4+5e3a11e2e7f952da93f9d35bd63a2fa181c0608b
    Composants C# utilisés dans l'IDE. Selon votre type de projet et vos paramètres, une version différente du compilateur peut être utilisée.
    Outils TypeScript 17.0.30715.2002
    Outils TypeScript pour Microsoft Visual Studio
    Outils Visual Basic 4.11.0-3.24376.4+5e3a11e2e7f952da93f9d35bd63a2fa181c0608b
    Composants Visual Basic utilisés dans l'IDE. Selon votre type de projet et vos paramètres, une version différente du compilateur peut être utilisée.
    Razor (ASP.NET Core) 17.11.3.2442001+68650a7d94261bc56a1f4bc522c2ee35314b1abb
    Fournit des services de langage pour ASP.NET Core Razor.
    SQL Server Data Tools 17.11.38.0
    Microsoft SQL Server Data Tools
    Test Adapter for Google Test 1.0
    Enables Visual Studio's testing tools with unit tests written for Google Test. The use terms and Third Party Notices are available in the extension installation directory.
    Visual F# Tools 17.11.0-beta.24317.3+c07c8ebad62f6629b36349381991a299598a8d74
    Microsoft Visual F# Tools
    Visual Studio IntelliCode 2.2Développement assisté par intelligence artificielle pour Visual Studio.
    2- The main issue, when installing nuget QuickOPC package :
    Le package « OpcLabs.QuickOpc 5.80.347 » est introuvable dans la ou les sources principales suivantes : « C:\Users\U\.nuget,C:\Program Files (x86)\Microsoft SDKs\NuGetPackages,C:\Program Files (x86)\OPC Labs OPC Studio 2024.1\NuGetPackages,C:\Program Files (x86)\Microsoft SDKs\NuGetPackages\, api.nuget.org/v3/index.json ». Vérifiez que toutes vos sources de package en ligne sont disponibles (OU) que l'ID de package et la version sont spécifiés correctement.
    But shouldn't using the OPC Labs OPC Studio 2024.1 setup prevent me from managing nuget packages ?
    (*) And sorry, the "EasyUAClient opcClient = new EasyUAClient.Create()" statement was a typo in my previous message.)
    29 Aug 2024 19:31 #13076 by support
    1. Can you please post here specifically the Visual Studio version you are using? (from the About box) - I know you wrote "last update", but please state the full version number.
    2. It would be easier to focus first on the "backup" approach you outlined ("EasyUAClient opcClient = new EasyUAClient.Create()"). However, the statement is incorrect already: you either do new EasyUAClient(), OR you do EasyUAClient.Create(). But not both. I doubt that the code you presented will compile. And, you wrote "... it fails at runtime with a similar exception.". I need the full text of that exception, knowing that is "similar" is not sufficient.
    When posting error messages, copy here the actual text you get. Do not attempt to translate it.
    Note that I am perplexed by the sentence "Last chance for me until I ask for hypothetical refund...". This is not the last chance - this is the first time you have contacted us about the issue (the Online Forums is where we provide tech support; other users can contribute too, but it is not common).
    Time to create page: 0.230 seconds
