Catching Exceptions with Read Multiple or Multiple -Operation Methods
25 Jun 2024 18:59 #12885 by support
The primary method for testing the result is the Exception property in the result objects. If it is non-null, there was an error, and it contains the exception describing the error. The Succeeded property is just a simplified test for "Exception == null|.
I do not quite understand what you are after, i.e. what you precisely mean by "OPC Server goes down". Are you looking exclusively for a situation when the OPC Server performs an orderly shutdown? Or do you want to include other situations as well?
25 Jun 2024 18:30 #12884 by KPersyn33
Hello Team,
I have been working with a customer who is using ReadMultiple and would like to have a catch for when the OPC Server goes down. On the docs it mentions that you should not put try/catch statements or similar constructs around calls to this method. The only exceptions thrown by this method are for usage errors, i.e. when your code violates the usage contract of the method, such as passing in invalid arguments or calling the method when the state of the object does not allow it. Any operation-related errors (i.e. errors that depend on external conditions that your code cannot reliably check) are indicated in the result objects returned by the method.
I was wondering if there was any other way or suggestions for knowing when the OPC Server goes down/or methods for catching those exceptions other than the 'succeeded' call.
Thanks!
