Browse Citect Plant SCADA doesn't show the items under the BrowseProvider folder
15 Jul 2024 05:56 #12943 by support
According to my records, the LooseReferenceTypes property was introduced in 5.80.191. So your code won't even build with with 5.80.82.1 if it contained a statement with LooseReferenceTypes.
I am concerned when you say "We have <some version> installed". For the problems with the compiled application, it does not matter what version you have installed using Setup on your development computer. What matters is which version of NuGet packages are referenced in your project.
In any case, you should reference NuGet packages versioned at least 5.80.191, build your app, and deploy it.
5.80.82.1 is not enough.
Regards.
13 Jul 2024 13:16 #12940 by micham
Correction: We have OPC Studio 2024.1 (5.80.82.1) installed. Should we install this version: 5.80.278.1 ? Will it fix the problem?
13 Jul 2024 13:01 #12939 by micham
We are using Quick OPC Version 2023.1 (5.71.334.1) and NuGet version 5.80.278.
We have added to our code the following:
uaDataDialog1.LooseReferenceTypes = True
We are browsing the Plant SCADA OPC UA Server.
The problem is: only the first folder is browsable and show all items and sub folder. All of the rest folders are empty and shows zero items and sub folders. See the attached screen captures.
Any idea why only the 1st folder shows the items?
    13 May 2024 16:03 #12783 by support
    1) Regarding the BC40056 warnings: Not sure. Would have to have the project. It could be that you have a separate project where you copied over the Import-s but have not actually referenced the NuGet packages.
    2) Regarding the IntellISense warnings: You have not provided the actual warning text. Since the editor is showing them in gray, it might be that those Import-s can be simply removed, because they are not used in that particular file.
    3) I am glad that LooseReferenceTypes worked for you.
    12 May 2024 13:16 #12780 by micham
    We have implemented the new version and this property:
    And it works as expected!
    10 May 2024 17:56 #12779 by micham
    In addition the Imports lines of the OpcLabs modules are in warning....
    Imports OpcLabs.EasyOpc.UA
    Imports OpcLabs.EasyOpc.UA.Extensions
    Imports OpcLabs.EasyOpc.UA.OperationModel
    Imports OpcLabs.EasyOpc.UA.AddressSpace.Standard
    Imports OpcLabs.EasyOpc.UA.Gds
    Any idea why?
    10 May 2024 17:49 #12778 by micham
    Thank you!
    I will try it. One question. I am getting these warnings. Do you know why?
    Severity Code Description Project File Line Source Suppression State
    Warning BC40056 Namespace or type specified in the Imports 'OpcLabs.EasyOpc.UA.Forms.Application' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases. UCMECFG D:\MyBin\Proj-VS2017\UCME-OPC\Version 2024.0\UCME_CFG_NET\UCMECFG\UCMECFG\Form1.vb 10 IntelliSense Active
    Warning BC40056 Namespace or type specified in the Imports 'OpcLabs.BaseLib.ComInterop' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases. UCMECFG D:\MyBin\Proj-VS2017\UCME-OPC\Version 2024.0\UCME_CFG_NET\UCMECFG\UCMECFG\Module1.vb 11 IntelliSense Active
    Warning BC40056 Namespace or type specified in the Imports 'OpcLabs.EasyOpc.DataAccess' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases. UCMECFG D:\MyBin\Proj-VS2017\UCME-OPC\Version 2024.0\UCME_CFG_NET\UCMECFG\UCMECFG\Module1.vb 12 IntelliSense Active
    07 May 2024 11:31 #12776 by support
    Please upgrade to version 5.80.191 or later - NuGet packages are now on www.nuget.org , and installation program (probably not necessary in your case right now, if you are referencing the packages from www.nuget.org ), on our Downloads page.
    The UADataDialog now has an addition LooseReferenceTypes property. It defaults to False, which is the old and correct behavior. You can set it to True before running the dialog. In this case, it will browse with "wider" parameters, in order to cope with non-compliant servers.
    Note that I do not have the Citect Plant SCADA server, not any other similarly misbehaving server, available. I therefore could not actually test whether/how the LooseReferenceTypes = True. Let's cross our fingers that it will do what you want.
    best regards
    05 May 2024 08:31 #12759 by micham
    A special setting will be great. I will only use it with Citect UA server. When can I expect this to be implemented?
    05 May 2024 07:59 #12758 by support
    To the first corrected link: The text under it says "The HasChild ReferenceType is an abstract ReferenceType; only subtypes of it can be used.". This proves my argument, and disproves theirs.
    To the second corrected link: That is a long text, so not sure what they wanted to say by linking to it. It contains the above text, plus additional parts in support of my arguments, such as that HasComponent is the reference type used for DataVariables.
    The fact that other clients show what you want has no significance. Those clients have a different purpose. They are designed to show everything. The browsing dialog you are using from QuickOPC to show *subset* of the address space. The subset is chosen as to show the nodes that can get you the actual data values. The fact that the server has chosen an incorrect (and, in fact, invalid) reference type breaks the OPC specification and therefore the QuickOPC cannot show the intended subset.
    The problem with "showing everything" is that there can be millions of other references that you do not want to see. So if QuickOPC was to show everything, it would work in this case (with broken server), but will not work well in other cases, with servers that actually do work well. That is not something I can allow.
    The solution would be to have a special setting that would allow you to specify that you explicitly want the broken behavior. Or, a new dialog for the same kind of browsing that other clients have. In both cases I would recommend against doing it, for the reason explained above.
