License error
02 Mar 2024 09:04 #12606 by support
Replied by support on topic License error
Key-Permanent-WebForm-1999320511-20231222.txt is the right file. But you are not actually using it. You are using the one from the year before. You need to install or embed the new one.
02 Mar 2024 08:39 #12605 by micham
Replied by micham on topic License error
Hi
This is the license file I have....If this is not the right license, can you please send me the updated license for version 2024.1?
Key-Permanent-WebForm-1999320511-20231222.txt Date: 11/20/2023
02 Mar 2024 08:04 #12604 by support
The error message tells you that you have license with serial number 1999321722 installed, and not 1999320511.
Check it.
02 Mar 2024 07:48 #12602 by micham
License error was created by micham
I have installed the latest version of Quick OPC (Setup-OPCLabs-OpcStudio-2024.1-Windows-Full). When I start my program I am getting an error:
My license is:
Can I get the permanent license?
