Match Pattern for Embedding a License
24 Jan 2024 10:25 - 24 Jan 2024 10:27 #12530 by support
Hello Nicole,
I was working with a customer recently who had a different problem, but I suppose the underlying cause is that same. I made a fix (into version 2023.2). Hopefully this will solve your problem as well. I will send you a download link to the new build of 2023.2 by email.
The version/build with the fix is 5.72.522 or later.
Z.
Last edit: 24 Jan 2024 10:27 by support.
23 Jan 2024 19:52 #12528 by nknox
I am just reaching out to note some behavior that a customer brought forward with the match pattern feature implemented in v2023.1. When using the recommended pattern, "*.Key-*.*", embedded licenses do not appear to be detected.
I have found that using "*.Key-*.txt" seems to work just fine, but the last wildcard has never worked for me in any configuration. We were able to replicate this across several machines, and saw the same thing in v2023.2 as well. I used the demo application and was working in VS2022.
Is there something we might be missing to make this work as recommended, or would this be considered a bug? Please let me know if I can provide any further context from my side.
Nicole
