How to subscribe to multiple OPC DA items, when amount of variables is changing?
20 Dec 2023 12:02 #12493 by mut9bu
20 Dec 2023 11:28 #12492 by support
It seems to me that you can simply do
client.SubscribeMultipleItems(dAItemGroupArguments .ToArray());
Is that what you were looking for?
The following user(s) said Thank You: mut9bu
20 Dec 2023 10:54 - 20 Dec 2023 11:13 #12491 by mut9bu
Hello
My console app has following arguments:
public string ip_address = Environment.GetCommandLineArgs()[1]; public string item_no = Environment.GetCommandLineArgs()[2]; public string item_1 = Environment.GetCommandLineArgs()[3]; public string item_2 = Environment.GetCommandLineArgs()[4]; public string item_3 = Environment.GetCommandLineArgs()[5]; public string item_4 = Environment.GetCommandLineArgs()[6]; public string item_5 = Environment.GetCommandLineArgs()7]; public string item_6 = Environment.GetCommandLineArgs()[8]; public string item_7 = Environment.GetCommandLineArgs()[9]; public string item_8 = Environment.GetCommandLineArgs()[10]; public string item_9 = Environment.GetCommandLineArgs()[11]; public string item_10 = Environment.GetCommandLineArgs()[12];
Due to the item_no parameter I tried to define a list of items:
List<DAItemGroupArguments> dAItemGroupArguments = new List<DAItemGroupArguments>(); public void item_list() { for(int i = 0; i < Convert.ToInt16(item_no); i++) { dAItemGroupArguments.Add(new DAItemGroupArguments(ip, server, Environment.GetCommandLineArgs()[i+3], 1000, null)); } }
So I should use always this list (or something similar) in the client.SubscribeMultipleItems(...) expression.
Last edit: 20 Dec 2023 11:13 by support.
20 Dec 2023 10:42 #12490 by support
It's easy to do. You just need to convert what you have into the form expected by the method. But I cannot answer it without knowing in which form (object types, their properties etc.) you get your items. Please share a piece of code illustrating that.
20 Dec 2023 10:27 - 20 Dec 2023 10:40 #12489 by mut9bu
Hello
In my C# .net framework 4.7.2 app I am subscribing to multiple OPC DA items. But my app is called from a parent app with arguments. That means, the number of items and the item definitions come from the argument parameters and changing each time.
Normally I subscribe to 3 items with following code. How should I modify my code, so that I can sometimes for example subscribe to 2 items sometimes to 8 items , depending on the argument parameters? With other words I would like to use a List of items for the client.SubscribeMultipleItems expression. But couldn't find the correct way for this.
using (var client = new EasyDAClient()) { client.ItemChanged += client_Main1_ItemChanged; client.SubscribeMultipleItems( new[] { new DAItemGroupArguments(ip, "OPC.IwSCP.1",item_def1, 1000, null), new DAItemGroupArguments(ip, "OPC.IwSCP.1",item_def2, 1000, null), new DAItemGroupArguments(ip, "OPC.IwSCP.1",item_def3, 1000, null), } ); } public void client_Main1_ItemChanged(object sender, EasyDAItemChangedEventArgs e) { if (e.Succeeded) { item_value = e.Vtq.ToString(); } // else { Console.WriteLine($"{e.ErrorMessageBrief}"); } }
Last edit: 20 Dec 2023 10:40 by support.
