Do you have a sample VB.Net project that uses UIAdministerApplication Method?
25 Sep 2023 18:19 #12232 by micham
You may ignore my questions. I have managed.
25 Sep 2023 15:29 #12231 by micham
Thank you for your answer. Do you mean like this:
IEasyUAClientServerApplicationExtension2.UIAdministerApplication(Application, Owner, clientSelector, allowChangePrivateKeyPassword)
How should I declare the IEasyUAClientServerApplicationExtension2 object?
25 Sep 2023 15:04 #12230 by support
Quoting from the page I referred you to:
"Call the UIAdministerApplication Extension Method, typically on the static Instance Property of the EasyUAFormsApplication Class. This way, your application can invoke the dialog when it is appropriate for you, such as upon a specific command from the application menu."
25 Sep 2023 14:52 #12229 by micham
As I have mentioned in the other topic, my project is working well. Thank you for your support.
I have tried this code:
<ComVisibleAttribute(False)>
<ExceptionContractVerificationAttribute(True)>
Public Interface IEasyUACertificateManagementClient
Inherits IEasyUACertificateManagement, OpcLabs.EasyOpc.UA.IEasyUASpecializedClient, System.IServiceProvider
'Usage
Dim instance As IEasyUACertificateManagementClient
The declaration return a compilation error....
Please adviase.
25 Sep 2023 14:47 #12228 by support
No, but the instructions on opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...UA%20Application%20Dialog.html are fairly clear.
Note that until the references in the project are cleaned, nothing is going to work.
25 Sep 2023 14:38 #12227 by micham
Do you have a sample VB.Net project that uses the UIAdministerApplication Method? I would like to include it in my project.
