Exception when trying to browse OPC Servers
21 Sep 2023 07:35 #12196 by support
Now the error is back to the assembly version mismatch which I have answered on the other forum thread.
We do not officially support older QuickOPC versions.
21 Sep 2023 07:08 #12191 by micham
Thank you for your answer. I have changed the definition per your advise. When I run my project I get an exception. See below. It is the same exception all the time. Something with the follwoing:
System.Runtime.CompilerServices.Unsafe, Version=5.0.0.0
System.Runtime.CompilerServices.Unsafe, Version=4.0.4.1
Note: I have different versions of Quick OPC on my server.
System.TypeInitializationException
HResult=0x80131534
Message=The type initializer for 'OpcLabs.EasyOpc.Forms.Browsing.OpcDialog' threw an exception.
Source=OpcLabs.EasyOpcForms
at OpcLabs.EasyOpc.Forms.Browsing.OpcDialog..ctor()
at OpcLabs.EasyOpc.Forms.Browsing.OpcComputerAndServerDialog..ctor()
at EBO_Browse.OPC_Servers_Dialog..ctor() in D:\MyBin\Proj-VS2017\EBO-OPC Client\Configuration(4)\OPC_Servers_Dialog.vb:line 34
Inner Exception 1:
FileLoadException: Could not load file or assembly 'System.Runtime.CompilerServices.Unsafe, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Inner Exception 2:
FileLoadException: Could not load file or assembly 'System.Runtime.CompilerServices.Unsafe, Version=4.0.4.1, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
I appreciate your help.
    21 Sep 2023 06:48 #12190 by support
    Look, this is a basic programming question/mistake. But it happens...
    You are missing the "New" keyword:
    Private OpcComputerAndServerDialog1 As OpcLabs.EasyOpc.Forms.Browsing.OpcComputerAndServerDialog
    should be
    Private OpcComputerAndServerDialog1 As New OpcLabs.EasyOpc.Forms.Browsing.OpcComputerAndServerDialog
    20 Sep 2023 18:33 #12185 by micham
    I have this variable definition:
    When I try browsing by this command:
    If OpcComputerAndServerDialog1.ShowDialog() = DialogResult.OK Then
    I get an exception:
    OpcComputerAndServerDialog1 was Nothing.
    System.NullReferenceException
    HResult=0x80004003
    Message=Object reference not set to an instance of an object.
    Source=EBOOPCClientCFG
    at EBO_Browse.OPC_Servers_Dialog.ButtonBrowseServers_Click(Object sender, EventArgs e) in D:\MyBin\Proj-VS2017\EBO-OPC Client\Configuration(4)\OPC_Servers_Dialog.vb:line 400
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
    at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
    at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
    at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
    at System.Windows.Forms.Application.RunDialog(Form form)
    at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
    at System.Windows.Forms.Form.ShowDialog()
    at EBO_Browse.Form1.SettingsToolStripMenuItem1_Click(Object sender, EventArgs e) in D:\MyBin\Proj-VS2017\EBO-OPC Client\Configuration(4)\Form1.vb:line 1605
    at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
    at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
    at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
    at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
    at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
    at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
    at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
    at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
    at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
    at EBO_Browse.My.MyApplication.Main(String[] Args) in :line 81
    Any idea what is wrong?
