Error BC30002 Type 'OpcLabs.EasyOpc.DataAccess.Forms.Browsing.DAItemDialog' is n
21 Sep 2023 08:14 #12199 by support
I have thought a bit more about possible causes for the problem with the assembly reference.
Can you please email me your .vbproj file again (i.e. now, with QuickOPC 2023.1 being referenced as NuGet packages)?
I want to check for possibly unwanted/unnecessary assembly references that might be causing this.
21 Sep 2023 07:18 #12192 by support
Hello, thank you.
From the files you have sent, the exception occurs, because the .config file contains
<assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1"> <dependentAssembly> <assemblyIdentity name="System.Runtime.CompilerServices.Unsafe" publicKeyToken="b03f5f7f11d50a3a" culture="neutral"/> <bindingRedirect oldVersion="0.0.0.0-5.0.0.0" newVersion="5.0.0.0"/> </dependentAssembly> </assemblyBinding>
which means that System.Runtime.CompilerServices.Unsafe assembly should be of version 5.0.0.0.
But, the actual System.Runtime.CompilerServices.Unsafe assembly in your project output is 6.0.0.0.
You need to figure out what is wrong in your project that causes this.
Give me also some time, I will investigate and think of possible causes. But ultimately, it is your task to resolve issues like this.
20 Sep 2023 14:57 #12183 by micham
When I try running the Release I get this exception. See the attached zip file - System.Runtime.CompilerServices.Unsafe.zip.
See the attached config file.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: An error occurred creating the form. See Exception.InnerException for details. The error is: Could not load file or assembly 'OpcLabs.EasyOpcForms, Version=5.71.334.1, Culture=neutral, PublicKeyToken=6faddca41dacb409' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) ---> System.IO.FileLoadException: Could not load file or assembly 'OpcLabs.EasyOpcForms, Version=5.71.334.1, Culture=neutral, PublicKeyToken=6faddca41dacb409' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
at EBO_Browse.OPC_Servers_Dialog.InitializeComponent()
at EBO_Browse.OPC_Servers_Dialog..ctor()
at EBO_Browse.My.MyProject.MyForms.Create__Instance__[T](T Instance)
at EBO_Browse.Form1.Load_GeneralSettings()
at EBO_Browse.Form1.Form1_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.9181.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EBOOPCClientCFG
Assembly Version: 1.0.108.0
Win32 Version: 1.0.108.0
CodeBase: file:///F:/Program%20Files%20(x86)/Control-See/EBO-OPC%20client/BIN/EBOOPCClientCFG.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.9037.0 built by: NET481REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.8.9172.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.9037.0 built by: NET481REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.ServiceProcess
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
File Name: System.Run...safe.zip
File Size:9 KB
File Name: EBOOPCClie...0.config
File Size:18 KB
    20 Sep 2023 14:57 #12182 by support
    Thank you. I need some more info.
    1) You wrote "when I run my project in debug mode, I get this exception.". What happens if you run the Release configuration?
    2) In the target folder of your debug configuration (probably bin/Debug), locate the file System.Runtime.CompilerServices.Unsafe.dll, zip it and post it here. I want to check its version.
    3) In the same folder, there should be a file like <you app name>.exe.config . Please post it here. I want to check which binding redirects are in this file.
    20 Sep 2023 14:47 #12181 by micham
    I have defined the components programmatically. See below. When I run my project I get the following exception.
    Public DaItemDialog1 As OpcLabs.EasyOpc.DataAccess.Forms.Browsing.DAItemDialog
    Public WithEvents EasyUAClient1 As OpcLabs.EasyOpc.UA.EasyUAClient
    Public UaDataDialog1 As OpcLabs.EasyOpc.UA.Forms.Browsing.UADataDialog
    HResult=0x80131509
    Message=An error occurred creating the form. See Exception.InnerException for details. The error is: The type initializer for 'OpcLabs.EasyOpc.Forms.Browsing.OpcDialog' threw an exception.
    Source=EBOOPCClientCFG
    at EBO_Browse.My.MyProject.MyForms.Create__Instance__[T](T Instance) in :line 190
    at EBO_Browse.My.MyProject.MyForms.get_OPC_Servers_Dialog()
    at EBO_Browse.Form1.Load_GeneralSettings() in D:\MyBin\Proj-VS2017\EBO-OPC Client\Configuration(4)\Form1.vb:line 202
    at EBO_Browse.Form1.Form1_Load(Object sender, EventArgs e) in D:\MyBin\Proj-VS2017\EBO-OPC Client\Configuration(4)\Form1.vb:line 76
    at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    Inner Exception 1:
    TypeInitializationException: The type initializer for 'OpcLabs.EasyOpc.Forms.Browsing.OpcDialog' threw an exception.
    Inner Exception 2:
    FileLoadException: Could not load file or assembly 'System.Runtime.CompilerServices.Unsafe, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    Inner Exception 3:
    FileLoadException: Could not load file or assembly 'System.Runtime.CompilerServices.Unsafe, Version=4.0.4.1, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    20 Sep 2023 13:57 #12179 by support
    Regarding the missing components: The project seems to be in somehow damaged shape. It should be possible to use the Toolbox to put them back, but I am afraid we would run into even more problem. So, if you can add them from the code, it would be the easiest at the moment.
    20 Sep 2023 13:52 #12178 by micham
    I see that the DA and UA components have disappeared from the form. See below.
    EasyUAClient1
    UaDataDialog1
    DaItemDialog1
    When I try to add these components from the Components Toolbox, I get an error. Should I add them programmatically?
    20 Sep 2023 13:52 #12177 by support
    20 Sep 2023 13:35 #12175 by micham
    Thank you for your answer. Yes. I have it. See below.
    20 Sep 2023 13:04 #12173 by support
    in your project properties, do you have "Auto-generate binding redirects" checked, as in the example below?
    If not, check this setting, save, and rebuild.
    Time to create page: 0.154 seconds
