EasyDAMultipleItemsChangedEventArgs
13 Sep 2023 14:15 - 13 Sep 2023 14:15 #12110 by PythonByte
hi,
in QuickOPC version 5.59 why this code doesn't work anymore, it was working in version 5.23? I can't find the DataAccess.EasyDAMultipleItemsChangedEventArgs it says not found?
Private Sub MultipleItemsChanged(ByVal sender As Object, ByVal e As DataAccess.EasyDAMultipleItemsChangedEventArgs) Handles m_opcClient.MultipleItemsChanged Dim Tags As New HQTags For i As Integer = e.ArgsArray.GetLowerBound(0) To e.ArgsArray.GetUpperBound(0) Dim Tag As HQTag = CType(e.ArgsArray(i).State, HQTag) If e.ArgsArray(i).Exception IsNot Nothing Then Tag.ServerError = e.ArgsArray(i).Exception.GetHashCode Else Tag.Value = e.ArgsArray(i).Vtq.Value End If 'Add Tag to the Tags collection object Tags.Add(Tag) Next i RaiseEvent MultipleTagsChanged(Tags) End Sub
Any help would be much appreciated
Last edit: 13 Sep 2023 14:15 by PythonByte.
