Exception while trying to connect to an OPC UA Server
14 Sep 2023 16:55 #12138 by micham
Yes. Windows Forms.
We get an exception. You can see the details in the attached PDF.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
    14 Sep 2023 16:44 #12137 by support
    You say that connection cannot be established with the "insecure" setting - but is it giving the very same error? (that would be weird).
    BTW, I understand your application is Windows Forms, right? Doesn't it pop-up any dialog when trying to connect to that server? (QuickOPC should do it, for otherwise unaccepted certificates).
    14 Sep 2023 16:42 #12136 by support
    The missing folder is kind of weird, but given that other folders. Besides the one mentioned, I would also expect the "RejectedCertificates" folder be there (in total, 4 subfolders). But yes, if it is missing, create it please.
    14 Sep 2023 14:52 #12134 by micham
    One more thing.... We have tried the IMPROPER (insecure) way by adding section below, but still the connection could not be established.
    If gAcceptAnyCertificate Then
    EasyUAClient.SharedParameters.EngineParameters.CertificateAcceptancePolicy.AcceptAnyCertificate = True
    End If
    Any idea why?
    14 Sep 2023 13:34 #12132 by micham
    You have mentioned that the certificate should be placed in these folder:
    "C:\ProgramData\OPC Foundation\CertificateStores\UA Certificate Authorities\certs"
    and
    "C:\ProgramData\OPC Foundation\CertificateStores\UA Applications\certs".
    My customer says that the following folder does not exist on his computer.
    Should we manually create this folder and place the certificate in it?
    See the attached screen capture.
    13 Sep 2023 13:03 #12107 by micham
    13 Sep 2023 12:52 #12106 by support
    I was referring to certificate stores on the client side. I gave the default locations that QuickOPC uses.
    13 Sep 2023 12:41 #12103 by micham
    Thank you for your answer.
    I think that you take it too personal... why should I make fun of you?!
    I am aware that the connection is insecure, but it is a connection and the customer can see values in UA Expert...See page 10 of 13.
    Regarding to your suggestion, ("The proper way of resolving this is, as I wrote: The CA certificate(s) need to be placed into the Trusted issuers store (in addition to Trusted peers). This should not be too difficult. They just need to know where their server got the certificate from (the CA). Then, whoever runs the CA should be able to give them CA cert (public part; in .DER format). And then just place it to "C:\ProgramData\OPC Foundation\CertificateStores\UA Certificate Authorities\certs" and "C:\ProgramData\OPC Foundation\CertificateStores\UA Applications\certs".)
    Is it on the server side or client side?
    13 Sep 2023 11:50 #12102 by support
    I cannot resist the feeling that you are making fun of me. Have you even looked at the document?!
    They are getting the SAME BadCertificateChainIncomplete error as you get with QuickOPC:
    And then they forcefully accept the otherwise untrusted certificate:
    So this is PRECISELY what I have predicted. They are NOT connecting securely, because they cannot be sure that the server they are connecting to is genuine, or fake/rogue.
    The IMPROPER (insecure) way of "resolving" it is e.g.
    - in UA Expert, accepting the certificate forcefully, as they did,
    - In QuickOPC applications: Set EasyUAClient.SharedParameters.EngineParameters.CertificateAcceptancePolicy.AcceptAnyCertificate to True ( opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User's...licy~AcceptAnyCertificate.html ).
    13 Sep 2023 09:40 #12101 by micham
    Here it is.
    Time to create page: 0.165 seconds
