System.IO.IOException instantiating EasyUAClient
16 Aug 2023 13:30 #12012 by sw34
Confirming that QuickOPC 5.71.333 resolves this issue.
Thank you for the quick resolution!
16 Aug 2023 12:52 #12010 by support
Please update to QuickOPC 5.71.333, hopefully it is fixed now.
15 Aug 2023 19:24 #12003 by support
I was able to reproduce the issue. Thank you for reporting it! There will be a fix soon, I will post here when it is available.
15 Aug 2023 15:32 #11997 by sw34
Running on WSL linux using .net6 and Quick OPC 5.71
I created the demo as described in opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User's...%20Visual%20Studio%20Code.html
Get this error when calling
This does not occur when running under windows.
"One or more errors occurred. (Access to the path '/usr/share/IsolatedStorage/4afkimrw.2cy/ut00wkwg.uzs' is denied.)"
stack trace
" at OpcLabs.BaseLib.Internal.TaskBackground`1.get_Value()\n at OpcLabs.BaseLib.Internal.Initialize`1.get_Value()\n at OpcLabs.BaseLib.Extensions.Hosting.ApplicationInstanceExtension.GetCommonStorageProvider(ApplicationInstance applicationInstance)\n at OpcLabs.BaseLib.Extensions.Hosting.ApplicationInstanceExtension.GetCommonStorageProvider(ApplicationInstance applicationInstance, String key, String[] subkeys)\n at System.Lazy`1.ViaFactory(LazyThreadSafetyMode mode)\n at System.Lazy`1.ExecutionAndPublication(LazyHelper executionAndPublication, Boolean useDefaultConstructor)\n at System.Lazy`1.CreateValue()\n at OpcLabs.EasyOpc.UA.Toolkit.ClientServer.UAClientServerEngineBase..ctor(IServiceProvider serviceProvider)\n at OpcLabs.EasyOpc.UA.Toolkit.Client.UASmartClientEngine..ctor(IServiceProvider serviceProvider)\n at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientEngineBase..ctor(IServiceProvider serviceProvider)\n at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientEngine..ctor(IServiceProvider serviceProvider)\n at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.EasyUAClientEngine.get_Instance()\n at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.NetSdkEasyUAClient.HookStaticEventHandlers()\n at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.NetSdkEasyUAClient.EnsureStaticActivation()\n at OpcLabs.EasyOpc.UA.Implementation.NetSdk.Client.NetSdkEasyUAClient.set_AdaptableParameters(EasyUAAdaptableParameters value)\n at OpcLabs.EasyOpc.UA.EasyUAClient.StaticActivate()\n at OpcLabs.EasyOpc.UA.EasyUAClient.EnsureStaticActivation()\n at OpcLabs.EasyOpc.UA.EasyUAClient.Construct()\n at Program.<Main>$(String[] args) in /home/sw/Hello/Program.cs:line 3"
