Freeze the whole application
09 Aug 2023 14:30 #11983 by support
Oh, thank you.
No need to delete unless you insist there is a necessity.
If there is a lesson learned - a solution you have found - we would welcome if you share it too.
09 Aug 2023 12:40 #11982 by mozesa
Replied by mozesa on topic Freeze the whole application
Consider it irrelevant. Problem solved.
You can delete it.
09 Aug 2023 08:47 #11981 by mozesa
await UADataChangeNotificationObservable .Create<bool>(_endpointDescriptor, _presenceSensorId, samplingInterval: 500) .ObserveOn(TaskPoolScheduler.Default) .Skip(1) .Select(x => x switch { { TypedAttributeData.TypedValue: true } => OperationTaskStatus.Ok, _ => OperationTaskStatus.Nok, }) .StartWith(OperationTaskStatus.New) .FirstAsync(x => x is OperationTaskStatus.Ok) .ToTask(cancellationToken, scheduler: TaskPoolScheduler.Default) .ConfigureAwait(false);
The above snippet works fine, but when the OPC UA server is offline, and I signal a cancel via the passed in cancellationToken, it freezes the whole application. I mean the whole GUI is got freeze. Even though it is wrapped by default a Task.Run. I checked, the code is running in .NET ThreadPool Worker. As you can see I set the scheduler as well, but no effects - the application gets freeze because of this code.
Thanks for your help in advance.
Best Regards,
